column floor mount possibility? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 01:48 PM
I was in the electrical Dept. at Home Depot and saw some 2" clamp connectors that I think would work for my floor column mount on my 1950 Jeepster. I bought 2 for $5 and cut the collar off one. Drilled its threaded holes out and used it for the moving part of the clamp. I made a plate to mount to the floor and drilled a 2 1/4" hole and put the clamp through the hole using its ring clamp. The angle turned out just right and my 2" column fits perfectly through the clamp. It all seems very secure, cheap, and easy to remove. Any thoughts would be appreciated? Thanks, Tom
Name:	steering mount 002.JPG
ID:	63727   Click image for larger version
Name:	steering mount 009.JPG
Old 03-05-2012, 03:19 PM
delawarebill's Avatar
your an official hot rodder now...
i wanted to make steps for my bucket for short legged people. did the sq tubing build and went to harley D for flat pegs... $60 bucks apiece??? don't think sooooo... was in lowes electrical a few days later and found chrome diamond plated sw covers...
i've had several people mention they liked the steps and wondered where i got the chrome step pieces.... Shhhhhhhhh !!
Old 04-19-2012, 11:19 AM
Additional Info on the Home made clamp
Hey Evan, would you happen to have any additional pictures. I don't understand how you joined the 2 clamps together? did you weld clamps.
So what I see is 2 C shaped clamps connected by 2 boths.
1 threaded clamp with a ring that tightens it to the sheet metal.
Maybe a few more pictures would help, I am at this step right now and love the idea of this, save me 60 buck.
Old 05-05-2012, 02:26 PM
pripat,
Here are a few more pictures. The clamps are electrical 2" clamps. On both clamps I threw away the steel clamp that moves and tightens with the screws. I cut the cast flange off behind the face by the 2" ring clamp on one clamp, and drilled the holes so the screws would pass through. I used this piece as the half that tightens with the screws into the other cast clamp. I took the shift arm off the column and slid on the clamp and replaced the arm. Then I slid the column and clamp through the hole I cut in the firewall. Hope this helps.
Name:	steering mount 001.JPG
ID:	65178   Click image for larger version
ID:	65179   Click image for larger version
Name:	steering mount 006.JPG
from the column to the floor... unearthly57 Transmission - Rearend 1 09-26-2011 11:28 AM
old column mount turn signal whatwouldscoobydo Electrical 16 07-13-2007 08:07 PM
High beam switch for GMH floor mount joshadelaide Electrical 3 07-16-2005 08:56 PM
floor mount clutch pedal 6speedwagon Transmission - Rearend 0 03-09-2004 01:45 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 06:56 PM
