Column Shift to Console Shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2006, 09:50 AM
I have a 1972 Skylark 2dr Coupe. not a GS, but nice just the same. I wanted to put the GS console with the shifter in with some bucket seats. How hard would it be to do so? I have already found the stearing column without the shifter on it, and the console with the hurst shifter. Is it merely changing a cable or much more?
Thanks
Wil
Old 06-04-2006, 12:03 AM
STRKD89FB's Avatar
408 Stroker
Not a real hard job to do. I have done it in a couple different cars. You will need to measure and drill holes to mount the console and shifter. Need to cut a hole to run the shift cable through and you will need the bracket to mount the cable to the tranny. As far as the steering column part I am not real sure cause I always left the column in the car. I just popped the pin out and took the shift lever off than covered up the area with something.
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
Column shift on a 50 Hudson?! jsrail Transmission - Rearend 3 11-02-2005 08:08 AM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
column shift into 54 chev PU DV8 Suspension - Brakes - Steering 6 04-22-2004 08:29 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 06:56 PM
