Column Shift Conversion Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2012, 05:55 AM
I recently purchased a steering column for my 1965 Mercury Comet Cylcone to replace the old column shift version I had since I use a floor shifter. The length and everything seems to fit good, but it doesn't appear there is anything from keeping the upper trim ring around where the steering wheel goes from sliding down when under the spring force of the final wheel assembly. The old column shift version had an inner tube that dead headed on the bottom to keep the upper trim ring from sliding down before. This assembly is different. Does anyone have any ideas? Seems like I'm just missing a part somewhere?
How to wire column shift light in flaming river steering column firstgear Electrical 6 03-02-2012 10:14 PM
67 Camaro column shift conversion super_silent Transmission - Rearend 2 07-12-2006 10:08 PM
Column Shift to Console Shift lonestarrodz Transmission - Rearend 1 06-04-2006 12:03 AM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
column to floor shift conversion cantspel Transmission - Rearend 14 12-28-2004 08:51 PM
