Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Column shifter on a mustang?
Old 12-19-2005, 09:06 AM
lanierledford lanierledford is offline
Marcel
Last journal entry: Choo-choo town
Steering a stang
It can't be that hard, if I could put a tilt chevy col. in a 40 chevy with late model fuse panel in, anybody could. I just got a chevy wiring diagram and labeled all the wires as per color coding and wired . using the late model fuse panel made it easier because it had the quick plug in for the turn signals speed control, and everything coming from the col. The price sounds cool for what he's going to do, as long is he make a clean cut job. I'd want to see some of his work on early models.
P.S. Don't forget that theres going to be a spot in the floor where you had the shifter. You can plug it, but you may need to re carpet the floor. There should be a Fairlane or falcon that had a shifter on them. You might even go with a tilt while you're in there. Marcel
