Column shifter options. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2005, 12:06 PM
Siggy_Freud's Avatar
Might have been better to post in Interior but I figured it being a Transmission component you might know some options. I have a th-350 in my 66 GMC that is a column shifter. I am looking for an aftermarket shifter that has a button built in that I could use for nitrous activation. The nitrous runs off a full throttle switch as well, however I dont want it activated in 1st gear and as I prefer to manually shift I just dont have enough arms to shift, activate an alternate button, and steer the vehicle. I realize they make floor shifters with a button in them however I was just curious as to what options are available for a column shift. Thought it might be a bit more unique and I could retain my middle bench seat.
Any thoughts?
Thanks,
Dylan.
Old 03-04-2005, 12:18 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You might be able to adapt an older GM pushbutton switch from a turn signal lever used originally for cruise control activation to the transmission shift lever.
You could also look into using an aftermarket shift lever "ball" with built in switch, although they might be a little bulky on a column shift lever.
Old 03-04-2005, 12:36 PM
poncho62's Avatar
Wiki Edits: 5
I used to see nitros switches that strapped to a column shifter all the time in the 70s.....probably can still get them.
Ontario Rodders
Old 03-04-2005, 02:50 PM
screamin340's Avatar
Is it Beer:30 yet?
This is probably stupid but what about a newer colum shifter ..with the overdrive button in the center
column to floor shifter camino_man General Rodding Tech 5 07-27-2007 08:24 AM
Column shifter indicator with overdrive? 70 sbc Transmission - Rearend 2 02-16-2003 05:54 PM
switch reverse ilghts from column to floor shifter MuscleBlock81 Electrical 3 09-16-2002 12:34 PM
Stock column shifter into B&M megashifter MuscleBlock81 Transmission - Rearend 2 09-11-2002 11:32 PM
Early GM column shifter & 700r4 56xpresso Transmission - Rearend 2 07-17-2002 02:56 AM
