Combination help I'm trying to build a 400sbc street/strip - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2012, 12:38 AM
I'm trying to build a street/strip 400sbc been looking at allot of forums and asking questions just trying to reach out and get a few pointers/routes to go wanna be at least 11.1 compression.
Old 08-15-2012, 04:52 AM
You can set it up for 11:1 cr with pump gas but the cam would need to be on the edge of being streetable (big cam). And big cams require lots of stall and gear. What are you gear and stall converter plans?
If you plan to use pump gas and drive it on the street I would limit cr to 10.5:1. There isn't much gain in power going that extra 0.5 cr but it does cause lots of tuning issues.
Read this 406 combo. makes almost 500hp with 87 octane.
Chevrolet 406 CI Engine Build - Chevy High Performance
Old 08-15-2012, 06:20 AM
Banned
Fwiw 500hp is about the reliable limit of a stock 400 block, even at that id do a partial block fill and be sure to use light components, a long rod, and a perfect balance job- assuming your wanting some longevity.
Old 08-15-2012, 08:38 AM
vinniekq2's Avatar
what car and what E.T.s are you looking for? start with the heads and work from there.Whats been done to the cars suspension and gearing,what tires?
Old 08-15-2012, 11:02 AM
Why so much compression? In and of itself 11 to 1 is easy to get, but what is the goal of the engine and what is the rest of the configuration you're thinking about?
Bogie
Old 08-19-2012, 11:13 PM
my plans are a street/strip type combination Im gonna bore it over to a 406 and its going into a monte carlo ss i think i wanna change the 3;73 gears some say i might need a stronger rear this is my first engine build
Old 08-19-2012, 11:55 PM
vinniekq2's Avatar
JT,what kind of car? what transmission is in the car?Are you going to race it as a bracket car? what bracket? Is your budget small? How much time do you have to build the motor?Are you doing all the work yourself?
please answer the questions so you can get started,,
Old 08-21-2012, 08:27 PM
Its Gonna Be A Street/Strip 1987 Chevy Monte Carlo Ss Mostly Going To Be Driven As A Weekend Hotrod That Packs Power If I Have To Mixed Gas Thats Fine My Budget Is 6-7k
street/strip s10 build HELP kennyhammond Hotrodding Basics 2 12-14-2011 08:46 PM
383 stroker build (street/strip) polkiewicz Hotrodding Basics 5 11-04-2011 10:57 PM
opinions on solid roller lifters for a street/strip car that sees more street time my87Z Engine 0 07-03-2011 09:20 AM
350 Street/Strip Build (Need Advice) Dreadhead Engine 22 11-04-2010 12:52 PM
350 Street/Strip Build (Need Advice) Dreadhead Engine 2 11-04-2010 10:00 AM
