Combination Value Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2007, 06:14 PM
I recently purchased a '68 Impala wagon which has a front disk brake conversion. It has a new booster and master cylinder. The front disk do not seem to be working at all as the rotors have a slight glaze on them like the pads have only been barely touching (the car barely stops). The rotors have no rust (if they had been sitting) or shine as if they were working. I bought a
motive products power bleeder as it is most likely a bleeding problem. My question is that the combination valve (which is the same as Master Power Brakes sells) seems to have a relief valve but is not the type that can be released to allow proper bleeding of the front brakes. What do I need to do the ensure that I properly bleed the front brakes to get everything working.
Old 05-01-2007, 06:36 PM
powerrodsmike's Avatar
Wiki Edits: 161
Put about 20-30 psi in your bleeder and bleed them as if there is no valve . The fluid should go right through.
Mikey
BE different....ACT normal.
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
