Combination valve for disk/drum setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2002, 06:13 AM
Post Combination valve for disk/drum setup
I am putting disks on my turbocharged flathead 6 50'Stude, and have installed Caprice rotors and Chrysler calipers. The master cylinder is below the level of the calipers. The rear brakes are Ford 8" drums. What vehicle can I get a combination valve from?
I also intend to use a #2 residual check valve to the disks and a #10 to the drums if none is part of the combination valve. I also intend to install a proportioner valve on the drums to adjust lockup. Thanks
<a href="http://cancermn.net/TS/TURBO.html" target="_blank">http://cancermn.net/TS/TURBO.html</a>
Greg
Old 04-01-2002, 06:39 AM
Smile
Hi Greg,
I believe the early 90'General Motors should have the portioning valve you want.Also they should have the 10# valve screwed into the back.Plus they are right under the hood.good luck
