Combo 3 in 1 Mill Drill Lathe - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 08:03 PM
chief36chevy's Avatar
Last journal entry: Hood holder/horn mount
Has anyone ever had any experience with a Combo 3 in 1 Mill Drill Lathe?
I am bidding on a Smithy AT 300 on eBay but cannot find any information on it. I am getting cold feet on this model. I will not be increasing my bid. I believe that it might be an older and discontinued model. What I am looking for is accessories for it just in case I get it.
Any suggestions will be appreciated?
Old 04-10-2011, 08:22 PM
BOBCRMAN@aol.com's Avatar
More of a model car. Small parts thing. Try www.Enco.com for toolimg
Old 04-11-2011, 05:24 AM
Are you sure you gave me the correct link? When I clicked on it I was taken to a web site that deals with DAD Digital Audio Delivery Systems. I could not find anything on 3 in 1 combo machines.
Old 04-11-2011, 05:25 AM
cal1320's Avatar
Look through here. [URL=http://www.chaski.org/homemachinist/URL]
They have a 3 in 1 section. I have one. Its good for making bushings and small parts. I find the lathe is the more useful of the 3. The mill lacks headroom for taller parts, the motor RPM is too fast, and there's not a lot of travel in the table. That said, they have their place in a home shop. They can turn out precise pieces if you take the time and get it squared up.
Unless you get a great deal I would pass. You will outgrow it quickly.
Old 04-11-2011, 06:10 AM
Sorry. The addy evidently changed www.use-enco.com/
Old 04-11-2011, 11:17 AM
I would STRONGLY advise avoiding any of the 3-in-one machines unless you are working primarily with plastics! They are so compromised in design in the attempt to do everything that they do nothing very well, they flex waaay to much and are a royal PITA to set up and use the different features. Look at the tall tailstock on those things, the Smithy is better thn most but still bad, that tall light weight tailstock and tall light tool post to accommodate the otherwise impressive swing on these machines leads to flex, loss of accuracy and just plain frustration to use. For what those things cost you would be far better to just buy a 12x36 stand-alone lathe and a small mill. The 12x36 and larger Chinese lathes are surprisingly good quality and a real bargain but anything smaller is not so good, the very popular 9x20 sold under several different brand names is just plain junk.
Also I agree that Enco is THE place for tooling and machine shop supplies, I buy almost everything I use from them.
Old 04-11-2011, 12:04 PM
cal1320's Avatar
I should also add when buying lathes and mills, you will probably spend what the machine costs for the tooling to go with it.
To Drill or Not To Drill Thermostat Sweet-34 Engine 21 01-08-2011 08:41 AM
How much could I mill off? lizardking7750 Engine 5 07-20-2009 09:37 PM
To drill or not to drill steam hole in 400 Curtis Thornton Engine 9 06-27-2008 12:44 AM
To Drill or Not To Drill (Carb Question) leejoy Engine 40 03-04-2006 07:41 AM
What do you do for a mill when you don't have one? Jag Daddy General Rodding Tech 10 06-01-2004 12:07 AM
