Combustion Chamber - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 11:25 AM
BG383's Avatar
BG
Combustion Chamber
Question: I have a crate 383 stroker (360hp/410lbs) on Sealed Hyperutectic Pistons(yields 9.5:1 CP, flat top, 2valve relief); GM Cast Iron heads (Valves: 1.94int/1.5exh)(72cc/170 runners)...Compressed Head Gasket of .041..Standard deck height..Comp Cams Hydraulic Flat tappet .477/.480 lift; 110 lsa; 224/230 dur. @0.50" Advertised Dur. 268/280. I want to run Aluminum Heads (preferable trick flow's, AFR, Dart) with 190 or 195 intake runners & 2.02/1.6 valves. What size Combustion Chamber should I use to keep a CP ratio of nothing greater 10.5. (Street Driven/ Maybe some Track car).....Thanks
Old 11-07-2008, 12:08 PM
Making a few assumptions here, but 8CC valve reliefs, 4.1 gasket bore, .030" down the bore, you could go as small as 60CC's.
Old 11-07-2008, 12:14 PM
lg1969's Avatar
Google "Tunnel Ram 406"
All you need is set of 70cc heads. This will bring you around 10.25:1 compression for -4 cc for a 2 valve relief
Thermal barrier coatings on combustion chamber and valves, any experience? Berliner Bel Air Engine 3 12-13-2007 11:36 AM
combustion chamber volume variances 383mudlust Engine 9 03-02-2007 10:05 PM
Combustion Chamber Volume Question mattson70 Engine 7 02-10-2007 02:25 PM
BBC combustion chamber sizes ratlover Engine 4 09-12-2004 01:02 PM
de-carbonize the combustion chamber KeithB123 Engine 23 10-01-2003 01:54 AM
