Come On Man! - Page 156 - Hot Rod Forum : Hotrodders Bulletin Board
  #2326 (permalink)
Old 06-28-2014, 02:48 PM
Originally Posted by 496CHEVY3100 View Post
Yes the engine does turn over ,have not tried to start it since it does not have provisions fot fuel pump ,not drilled so I will have to run an electric,
I have turned the engine to install the distrubitor,,and I can put transmission in neutral and drive shaft turns easy,but when I put transmission in gear driveshaft will not turn,i can hold in the clutch in and put a 24in pipe wrench on drive shaft and it will Not turn with clutch pushed down ..I am down to thinking the flywheel bolts are to long,the heads not the bolt they are ARP 12 point they are really the only change I have made before the problem veside flywheel which the engine had a flexplate and the 72 flywheel has a different bolt pattern ,can go with original bolts they are SAE and this engine is Metric,????
OK, This is a long shot but suppose hub of the clutch disk was interfering with the throw out bearing and it could not travel far enough to release the pressure plate...Incorrect clutch disc or in backwards??
  #2327 (permalink)
Old 06-28-2014, 03:09 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
WOW !! Hope no one was in that,
  #2328 (permalink)
Old 06-28-2014, 03:15 PM
Built Not Bought
I will answer on other site ,,would not want to upset the guy with the Ice Cream truck.
  #2329 (permalink)
Old 06-28-2014, 05:31 PM
Originally Posted by boothboy View Post
bb
lolololololol
  #2330 (permalink)
Old 06-28-2014, 10:42 PM
BB
Tops chopped, cheap
  #2331 (permalink)
Old 06-29-2014, 10:38 AM
Just after UPS started using some of the new Dodge Sprinters I happened to be in town when a Tractor with a Low Boy went by with a UPS Sprinter tied down on it. The van looked just about like the flattened car in the photo. I was talking to my driver about it and he told me that the van was moving when the tree fell and it crushed about three feet behind the driver! Fortunately he wasn't injured. I'll bet his shorts were a little browner than usual!
BB
  #2332 (permalink)
Old 06-29-2014, 12:54 PM
Banned
Found this on CL
For sale is a very unique, and well built Custom Fiberglass Roadster. It is built on a 1974 VW convertible
ID:	157705   Click image for larger version
ID:	157713   Click image for larger version
ID:	157721   Click image for larger version
ID:	157729   Click image for larger version
  #2333 (permalink)
Old 06-29-2014, 12:59 PM
Built Not Bought
Good use of a Super Beetle.
  #2334 (permalink)
Old 06-29-2014, 01:29 PM
That goes under the heading of "HOLY CRAP that was a ton of really nice work"! Politely leaving out any mention of what it looks like.
  #2335 (permalink)
Old 06-29-2014, 01:39 PM
It's.... Ummmm.... Interesting
  #2336 (permalink)
Old 06-29-2014, 07:56 PM
Built Not Bought
Interesting as to why only 1 cooling duct for the engine ,could have used a dummy on the other side ,,just me but I like it,
  #2337 (permalink)
Old 06-29-2014, 09:09 PM
I saw this on my wife and my evening walk tonight.
ID:	157818   Click image for larger version
  #2338 (permalink)
Old 06-29-2014, 10:01 PM
You just never know when you might need a super hero!
John
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (06-29-2014)
  #2339 (permalink)
Old 06-30-2014, 12:52 AM
Semper Gumby
Wiki Edits: 2
You saw that on your wife? Was she hurt?
  #2340 (permalink)
Old 06-30-2014, 01:07 AM
Built Not Bought
With enough time ,you can ????
automotive photography, humor
Man I need some help ivanogburn General Rodding Tech 9 10-29-2013 07:00 PM
help this man out roberteucare Introduce Yourself 1 07-06-2007 12:43 AM
New Man 37 Ford Introduce Yourself 1 11-09-2005 04:21 PM
Man oh man... I wonder if I could have a hot rod that passes emissions tests? r8ptan8 Engine 20 01-07-2004 05:59 PM
man o' man.......... crazy larry Hotrodders' Lounge 2 06-11-2003 09:19 AM
