Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Come to the masters of making things work
  #18 (permalink)
Old 01-12-2013, 08:41 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
the wheel cylinder system? is it homemade? are the bottom wheel cylinders mounted upsidedown? what do you use to split fluid flow on the rear cylinders? do what cobalt said about adjusting shoes. Are the shoes correct?how many adjusters are on the rear wheel systems? Is there an emergency system on the rear brakes. can you take a picture front and backing plate and post it?
