Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Come to the masters of making things work
  #20 (permalink)
Old 01-13-2013, 04:02 AM
Oilyrascal Oilyrascal is offline
Originally Posted by vinniekq2 View Post
the wheel cylinder system? is it homemade? are the bottom wheel cylinders mounted upsidedown? what do you use to split fluid flow on the rear cylinders? do what cobalt said about adjusting shoes. Are the shoes correct?how many adjusters are on the rear wheel systems? Is there an emergency system on the rear brakes. can you take a picture front and backing plate and post it?
Hello, no its not home made, here is a picture of the front front view, sorry I do not think I have a picture of the backing plate for the front ......and here are the rear brakes
The bleered are on top.
Two adjustors on the front and rear top and bottom
I use the factory splitter located on the top of the housing and then there are factory split lines between cylinders
