Brake adjusting...........
Heres a real redneck way 0f adjusting your brake shoes (im one)(and it works) take a 1x2 about 18 inches long.take 2 skinny nails,,grind the head off,nail one nail into board,put the end of board with the outside of nail touching the brake drum,mark other end of board where inside of drum is,put nail into mark,put board up to the inside of drum, the outside of nails should be touching drum 180 degrees apart, use the INSIDE of nails to adjust brake shoes,this will get you really close...
It'll take there being no air to have this set-up working correctly; there's no room for air being compressed taking up pedal travel. Once that's taken care of you should be back in business. |
Thanks anyway though, I think I have about got this licked anyway, I plan to bleed them one final time tomm now that I have the leaking line straightened out and see where I stand. |
I must ask.
Why are you changing from brakes that worked to an unkown??? Why not repair the brakes to factory specs. and have brakes that are safe. |
I repaired that leaking brake line yesterday and just now finished bleeding them, I have all 4 wheels locked up tight now, I am not happy with the amount of pedal travel though to do it, I would guess it to be about 3/4 of its full travel, of course on the second pump its right up nearer the top.
I do not think there is much else to do as far as bleeding, this is night and day to the first time I went thru this with the smaller bore master so I am pleased in general. I am going to get it going now and hopefully drive it within the next couple of weeks and see what it does, I do not have any doubt that the truck will stop just fine, I may still have to look at the possibility of adapting a larger bore master cylinder to the booster I have now if this pedal travel is bugging me still. I see no reason to scrap all of my hard work and head a different direction. I do however accept that I really do need the larger bore master, it does make that much of a difference so lesson learned. I cannot help but wonder though what would a smaller diam 3/16 line do, from what I have read putting a larger line say 5/16 will of course increase the volume which is what I want but that will also increase fluid expansion which would possibly lead to a mushy feeling within the brakes. So what would happen if I went to a smaller brake line, I am thinking that once the line is filled ( with no air ) than it is filled and so possibly adding the addit. pressure to the line may benefit. Its all speculation, like the saying goes technically a bumble bee cannot fly but I would like to hear your thoughts/speculations on this. Thanks for all of your help/suggestions Last edited by Oilyrascal; 01-15-2013 at 06:53 AM. |
Oilyrascal,
Adjust the brakes again. The back ones for sure. Adjust the front shoe then the back shoe. You should feel them grabbing the drum as you turn the wheel. Just so you know changing the size of the lines will not raise the pressure in the system only the amount of pressure it takes the push on the pedal. Leave the lines alone and drive safely. Scholman |
| Making wheels at work...... Thought I'd share | zbhover | Hotrodders' Lounge | 5 | 11-20-2011 07:35 PM |
| The little things you wind up making.... | Centerline | Hotrodders' Lounge | 10 | 10-17-2010 08:13 AM |
| Making Things Right... | onovakind67 | Off-Topic | 2 | 11-07-2006 01:06 PM |
| Funny things heard at work. | schnitz | Off-Topic | 33 | 11-08-2005 07:17 PM |
| Making Progress or making more work for myself?! | Weimer | Hotrodders' Lounge | 5 | 02-15-2004 03:11 PM |
