comet won't idle in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2005, 09:30 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
okay so i was driving my 65 merc comet with a 289 and c-4. So i got on the motor and took it up to about 80 mph pretty fast.but when i stopped at the next stop sign it wouldn't idle. i was home shortly after and shut her down. then i started it to bring it into my shop. now it idles like crap and as soon as i put it into gear it instantly dies. i messed with the carb but got no results. do you guys thinks it's just a really bad vaccum leak or is it something worse.
Old 05-05-2005, 09:36 PM
coldknock's Avatar
Vacuum leak or the timing is off somehow.
You might have popped an intake gasket or the distributor wasn't clamped tight enough and it turned a bit when you stepped on it.
Larry
Old 05-05-2005, 09:48 PM
comet boy's Avatar
Those were my main ideas but i wanted a second opinion before i started looking all over for the leak. i think i check the distributer first. thanks for your help.
Old 05-06-2005, 03:09 PM
Chevymetal's Avatar
High Octane
I agree with coldknock, it sounds like a timing issue.
Could be in the valve train. Pull your valve covers off and looks everthing over. Grab each rocker and wiggle it to see if anything has worked lose and you might want to have someone bump the car over several times to make sure everything is working the way it should.
And sometimes it's just the simple things; check your plug wires and make sure one hasn't popped off, and you might want to check your plugs.
Rear-end Setup opinions RObs71Nova Transmission - Rearend 6 03-11-2005 05:54 PM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 05:53 AM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
