Commander 950 oxygen sensor needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 07:37 PM
Last journal entry: Latest picture
Anyone know which aftermarket narrow band oxygen sensor will fit the commander 950?
I've been searching and found 2 that may work;
First is a Bosch #12008 which some claim will bolt right in and has the same plug end. It's originally for a 1987 Jeep 2.5L
Second is a Bosch #13077 which is the same as the popular mid 90s GM AFS-74.
I'm more inclined to use the 13077 because all of the sensors used on the commander 950 are from mid 90s GM.
Thanks for any help!!
Dan
Old 06-26-2012, 07:16 AM
35WINDOW's Avatar
Last journal entry: Engine!
Dan,
This is an obvious solution, but have you called Doug and the guys at Holley Technical Support? They are very helpful, and I'll bet they have the answer-good luck-
Old 06-26-2012, 07:23 AM
Originally Posted by 35WINDOW
Dan,
There's 2 reasons why I have not done that. First, I know their answer will be to use Holley part# XXX-XXX which will be double the cost of what it should be.
The other reason is that I'm located in Canada, and I will end up paying triple the cost because I live here, and it will take 2 weeks to get the part.
However, I will take your advice and give them a call to see what they say.
Thanks, Dan.
Old 06-26-2012, 05:41 PM
Ok, I found out which O2 sensor will work. I figured I would post my findings in case someone finds this during their search.
Standard # SG20
Bosch # 12008
NGK # 23502
These are all the same, and are originally designed for a 1987 Jeep Commanche 2.5L
Hope this helps someone. :-)
who has used the holley commander 950 tbi/mpi ? htwheelz67 Engine 2 01-08-2008 08:24 PM
Holley Commander 950 MPFI Sir Joab Engine 1 03-04-2007 12:16 AM
Holley Commander 950 Injection *** hotrodf1 Engine 7 07-14-2006 04:49 PM
Holley stealth ram/commander 950 fuel maps for tt v8 speedingpenguin Engine 6 06-08-2004 06:13 PM
Need help with Holley 950 Commander jhaynie Engine 0 10-14-2002 08:42 AM
