Comments on my T bucket brake set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2005, 11:54 PM
ken47's Avatar
I would like comments from knowlegeable folks on my T bucket brake set up. I have a manual MC from a 78 chev 1/2 ton, which had front discs and rear drums, it is a 1" bore MC. I am using late model chevy metric front discs and ford 8" rear drums (it has 1 1/2 wide brake shoes). I am not certain what pedal ratio to use. I see 5:1 and 6:1 are generally recommended for street rods with manual brakes, but the bucket is pretty light. A shorter pedal would be better for clearance issues around the steering column but it stll needs to be safe to drive (which includes stopping). Any comments would be greatly appreciated.
Old 10-25-2005, 04:54 PM
http://www.mpbrakes.com/mpfaqmasters.htm
This site has a lot of good info.....which answers some of your concerns..
DEUCE........
Old 10-25-2005, 07:55 PM
What year car are those front calipers from? In 83 (I think?) GM started using calipers that were made that would retract the piston more in the never ending quest for more fuel economy. To keep peddle travel down they also started using the step-bore "quick take-up" master cylinders. Keep the years paired between calipers and MC's. If the calipers are post 83 use a post 83 MC. If you are looking for post 83 manual brake stuff S10's are a good place to look.
Old 10-25-2005, 09:27 PM
ken47's Avatar
Thanks for the info.
Hi Triaged
Thanks for the information. The calipers I have are 78 Chevy metric versions from a car. The MC I have is from a 78 Chevy 1/2 ton truck (disc/drum set up 1" bore). I never thought of an S-10 as a potential candidate for an MC.
Thanks
Ken
Old 10-25-2005, 09:42 PM
It is hard to tell what people mean by "late model". I was only 2 in 78
I thought the 1/2 ton MC was 1-1/8"?
S10 is 15/16" on the small bore. The large bore depends on if it was manual or power brake. The smaller bore will make stopping hard easier and the step-bore should keep peddle travel down but will make you have to put more effort for gentle stops (which is why the manual brake has a smaller step-bore). S10's used the same spindles/brakes as G-bodies and the suspension is almost identical...they are also very easy to find in j/y's.
Old 10-26-2005, 01:59 AM
abstruse dutch uncle
Manual 1/2 ton was 1", but power brakes did use the 1 1/8".
Anyway Ken, here's my input...
Your caliper pistons are 2.5" diameter.
Your master cylinder is 1" diameter.
IMO you should use the 6:1 pedal.
You can go with a 5:1 pedal to see how you like the feel. If it is too stiff for you, you can change the master to a 15/16" bore or 7/8" bore. Some people prefer a stiffer pedal, some softer. It also depends on some other factors.
The 1978 Chevrolet midsized vehicles with those metric calipers used a manual pedal of about 5.35:1 and a 7/8" diameter master. The power master was 15/16" diameter.
I find the area [pi(radius squared)] of one caliper and the master and then use this formula:
{(1 Caliper Area)/(Master Area)}x(pedal ratio)=Overal Ratio
The overall ratio normally should fall between 30-50:1 for manual brakes. Lower is stiffer, higher is softer. Caliper efficiency, vehicle weight/rear brakes, hose flex, and pad compound are some things that can influence your decision.
90% of factory cars I checked (manual brakes w/ front disc) fall in right around 45:1.
1997 blazer..Brake booster gone bad? RodFather Suspension - Brakes - Steering 2 06-17-2005 02:26 PM
brake lights stay on.... jmtw Electrical 6 03-06-2005 08:48 AM
Painless Prod. brake liteswitch/vacuun sw. 39chevy Electrical 1 07-23-2004 07:33 PM
Brake Job Finally Finished 454impala69 Suspension - Brakes - Steering 1 04-24-2002 11:00 AM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 07:22 AM
