Common Causes of Water Pump Failure - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 06:28 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
It seems simple enough,but maybe some of the readership will find this useful.
Common Causes of Water Pump Failure: Engine Builder
Old 05-11-2013, 06:57 AM
vinniekq2's Avatar
I remember when the 327 was very popular.Biggest cause was over tightening the V belt.We did this because the 327 revved so fast it tossed the belt almost every first gear full throttle shift.We made deep pulleys until we were smart enough to use brackets that moved the alternator(remember generators back then) and used a shorter belt.
who didnt carry a spare belt back then?and "no" the panty hose/nylon trick advertised back then ,did not work
The Following User Says Thank You to vinniekq2 For This Useful Post:
Richiehd (05-11-2013)
Old 05-11-2013, 11:31 AM
1Gary's Avatar
Shhhhhh.Don't tell them that Vinnie about the panty hose.I'm still using that one to get them off women.LOL!!!!.
Old 05-11-2013, 08:49 PM
vinniekq2's Avatar
liquor is quicker
SBC Long water pump or short water pump? johnnnz Engine 28 08-21-2011 01:20 PM
short water pump vs long water pump Studedean Engine 9 07-20-2011 03:38 PM
94 Mustang 5.0l thermostat or water pump failure? frankenvette Engine 14 01-01-2008 10:09 AM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
