#1
comp
Input Parameters Are the Following:
Cylinder head Volume (CC) = 76.00 Piston Top Volume (CC) = -12.00 Cylinder Bore (Inches) = 4.0 Cylinder Stroke (Inches) = 3.48 Deck Height (Inches) = 0.000 Head Gasket Thickness (Inches) = 0.040 Computation Results: Computed Compression Ratio is 10.9 to 1 does this seem right it seem kinda high to me. the pistons i have are stl=H345np60 and they are even with the deck Register now (free) or login to remove ads |
#2
I bet on the "Dome CC" section you put in "12" instead of "-12".
#6
Approximately 9.44 - 1. Ed Edit: This site (www.smokemup.com) has some of the best calculators I have come across. I think you need to join as a member, but again, some of the best you will find on the net. Ed Last edited by edge : 05-18-2005 at 12:34 PM. |
#9
Comp
yea i got close to what edge got using my own home made excel file.
76cc heads 12cc of piston volume 10 cc for the gasket 4.00 bore and 3.48 stroke I got 8.312:1 You went the wrong way with the piston cc's.... most calculators need a minus number for dome pistons and a regular number for flat tops. Meaning that you are losing -12cc of volume instead of gaining 12 cc's like you would with a flat top below the deck.... Keith |
#10
76 cc = Approx. 8.6 - 1 64 cc = Approx. 9.7 - 1 Ed Last edited by edge : 05-18-2005 at 01:01 PM. |
#12
Thats how he calculated it. Looks at the bore measurement he entered. 4.06.
Bringing history and technology together. |
#14
comp
11.55:1 with the 49cc heads
keith |
| Thread Tools | Search this Thread |
| Similar Threads for: "comp" | ||||
| '74 Corvette 454 dyno results- Comp Cam XE 274H questions | Bob Turner | Engine | 12 | 05-19-2005 11:59 AM |
| Perf. RPM cam same as Comp "XE" series? | Dano1972 | Engine | 8 | 03-24-2005 05:17 PM |
| Comp T/A edition Trans Am | Tyson Reents | Introduce Yourself | 1 | 10-12-2004 08:53 AM |
| Comp Roller Cam | solidaxel | Engine | 3 | 07-24-2004 10:10 AM |
| Comp roller rockers | Terry411 | Engine | 2 | 06-03-2004 02:00 AM |
