comp cam 275 deh - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 06:14 PM
comp cam 275 deh
ok my cam is the 275 deh 275/277 adv 219/229 @50 462/482 lift lobe sep is 110 will it have a noticeable lope to it and if anybody has the same cam and has a video to share i would appreciate it
Old 06-02-2013, 07:19 PM
vinniekq2's Avatar
It may have a mild lope if used in a small engine.
The Following User Says Thank You to vinniekq2 For This Useful Post:
plumcrazyopa (06-02-2013)
Old 06-02-2013, 07:31 PM
comp cam 275 deh
It's a 400 sbc
Old 06-02-2013, 09:07 PM
Need a little more duration and a little less LSA to get the bad-*** lope you want. 230/240* intake....236/246* exhaust @050. Having a little more duration on the exhaust also gives that thumping sound at idle also. 108/106* LSA should make it "cut-up" pretty good!
6sally6
The Following User Says Thank You to 6sally6 For This Useful Post:
Old 06-02-2013, 10:25 PM
comp cam 275 deh
thanks for all the help
Lunati Cam 00010LK vs Comp Cam CL12-242-2 hollingshedlr Engine 2 05-14-2009 06:47 AM
comp cam kevo95 Engine 1 04-28-2009 02:14 PM
Which Comp Cam? jim1967 Engine 5 03-11-2009 12:40 AM
comp cam 86 red dragon Engine 2 02-16-2009 09:21 PM
comp cam cam lube runn141 Engine 3 12-18-2006 08:37 AM
