comp cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2010, 09:45 AM
rachet ralph's Avatar
comp cams
i was on the other day an seen a couple post about the cam wiping out with in miles from 50 to 200 miles, i just did a cam change for a guy that bought a cam for his 1974 impala an one i took out was a comp cam an number 8 exhaust was wipped out an now he bought a comp cam high engery cam an having trouble with same cylinder same lobe an i honed the lifter bores before doing swap an i ran engine at 2,500 RPM's for about 45 min. for break in an changed oils right after that, an nexted day guy came back an had one lifter tapping, so i pulled covers an reajusted all the lifters in the car, an 3 hours later guy came back with one tapping again an was same one as first time i reajusted them number 8 exhaust as same one was wiped out in cam i removed!, an seems that rockers not lifing as far as the rest i checked rocker studs an they measure same hieght as the rest as i've had some studs pull out the heads on stock chevy's, an when did change i put new pushrods in an new rockers with groved balls! all from comp cams, so as i read in the other post guy said his was number 8 exhaust lobe wiped out! has anyone else had there on number 8 exhaust go out on them? i've used comp cams in the past because had alot problem with crane cams in the past so i switched to comp cams, now is its like read in the post now there seems be a problem with comp cam's!!!!!!
Old 07-29-2010, 02:06 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...ips_and_tricks
Old 07-29-2010, 03:31 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Too bad about that... not good news
essentially tech's link describes proper installation practices to lessen the chance of failure on any flat tappet cam, not saying you did not follow this or that you did something wrong but any make of cam can go south even if these steps are followed. I had a comp XE cam and it did not fail or wipe but it/the valve train made noise, it is a common thing but comp gets mentioned more, maybe cause they sell the most or are more popular? I don't think that #8 is a more likely candidate to wipe either but this particular cyl is also motioned allot in other threads for different reasons, not cam timing. So now what different make?
Old 07-30-2010, 12:25 AM
well the one i read guy said his was #8 exhaust but now can't find the post!
Old 07-30-2010, 06:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Real informative post!
One thing, regarding changing oil after cam break in, my thoughts on it are to change even before one hour of run time. After the cam run-in is over, I dump the oil and filter, right then and there.
This isn't because there's metal clogging the filter, but the moly lube- mainly if it's the thick, black kind- can clog up the filtration media of an oil filter.
I don't even know what the cam makers recommend- it's just one of those things I've always done, and always will do, I suppose. Call it tradition. Or maybe superstition. lol
I should add, all the engines I build get the filter pad bypass plugged if there's one there to plug. This means all the oil tries to pass through the filter- and as a result if there's any blockage, the oil pressure drops.
Old 08-06-2010, 10:11 AM
well took off intake an pulled lifter out an cam was ok but lifter was about a half inch wore off it clean throught to the oiling hole! put another lifter in a guys driving it all i know is i'll never buy a comp cam again!!!!!!
Old 08-06-2010, 10:19 AM
Cam was OK??? Thats unusual. On a few occasions, when the retainer clips fail, I have changed a few lifters through the dist hole rather than pulling the intake.
Old 08-06-2010, 02:53 PM
ericnova72's Avatar
More for Less Racer
It will be back, and when it is both the lobe and the new lifter you just put in will be shot too. There is no way you should have reused that cam, no matter how good it looked to the naked eye. There is no way the lifter wears like that and doesn't alter the lobe it is riding on...no way, no how.
It has nothing to do with Comp Cams, it is a problem with modern oils not being formulated any more for flat tappet use. Do a search on Cam break-in and motor oil and you will find all the info you need.
Old 08-06-2010, 05:37 PM
BOBCRMAN@aol.com's Avatar
I am going thru a similar battle with a customer..
Built a 355 for this guy. Basically a stock cast piston 355. He insisted on A pair of 230 runner heads. victor jr. intake and a .557 solid lifter cam. Roller rockers, etc.
I knew this was going to be a troubled engine from the start. I informed the customer that the cam was way too big for motor. He doesn't know basic maintenance of an automobile. Can't lash hydraulics, but he says he has buddies who know everything..
Picks up motor three months after it's done. Takes three weeks to get it running..
On his invoice.. It stated what cam specs were, cam has been lashed at .020", copy of cam card and box. Also stated was requirement of camshaft break in lube. Required oils and proper break in procedure..
Copies of camshaft and parts warranties(NONE OF WHICH COVER HOT ROD/RACING CAMS).
When the motor left I bet my partner that I didn't think it would last a week.. Then, of course we'd be the bad guys...
Customer gets motor running, fuel and distrib problems (actually caused by his experts improperly re-lashing the valves). Can't get it to run much over idle.
It took 20 min to wipe lobes off cam. When asked what break in lube he used? None, couldn't afford $12.00 for bottle. What oil? Wal-Mart 20-50..
Wants me to warrantee motor.. NO...Brings down his whole family.. Thought there was going to be a major riot..on and on for the past week..
Old 08-06-2010, 05:46 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Oh man . What a mess . I hate dealing with people who have not a clue and then when something goes wrong , it's your fault. He could afford to have you build an engine and then has his buddies re-adjust the valves and can not afford $12.00 cam lube . GRRRRR Makes ya want to go bite a tree . (yooper by birth)
Old 08-06-2010, 06:10 PM
Wiki Edits: 326
BBC builder on another forum will not use a flat tappet cam without the customer signing a release of liability form. When the customer picks up the motor, that's the end of it. The builder has no further responsibility. He will warranty the motors he assembles with roller cams, but not flat tappet builds. Makes sense to me.
Old 08-06-2010, 11:20 PM
yes i know , but guy owns the car said he's going to run it till lobe is wiped off , but why he runs it , it will be trowing a rod out the side any way! runs it till valves float, told him before with last engine can't do that ! he said i dont care i'll just build another one! so we'll see if which happen's first rod or cam !! LOL!!
SBC Comp Cams valve spring, pushrod, break-in questions dlisabeth Engine 2 05-17-2010 07:10 AM
comp extreme energy cams 86SSman Engine 10 03-13-2010 12:12 AM
What all do I need to do to get a custom grind from comp cams? eric32 Engine 4 06-09-2009 09:07 PM
Comp Cams Solid Roller Lifters - Difference between 819 and 866? leejoy Engine 3 12-05-2007 11:42 AM
Comp Cams 46_stvblt Engine 6 01-22-2004 10:02 PM
