Comp Cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2012, 07:10 PM
New Member
Comp Cams
Hey there, has anyone used a Comp cam part # 32-221-3 Grind # 268H. Would like to know what your experince has been with this cam. Please let me know ,Thanks.
Old 12-15-2012, 12:06 AM
Comp cams
First, what is it going into, vehicle type, weight, gear ratio, daily driver, ETC. I Have used the CC 268 Hyd in mild SBC 350, approx 8.5 compression and a two barrel in a 80 camaro with a manual 3 speed. I only used it because at the time it was a cheap rebuild and I had the cam on the shelf. It ran very good and was a daily driver. I was actually surprised because I haven't had good luck with Comp Cams hydraulic grind durability.
camshafts, engine, performance, rebuild motors
Comp Cams 87monte385 Engine 5 03-04-2011 02:53 PM
comp cams rachet ralph Engine 11 08-06-2010 11:20 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 04:01 PM
Comp Cams 46_stvblt Engine 6 01-22-2004 10:02 PM
comp cams carnell Engine 6 07-21-2003 03:57 PM
