Comp Cams 268HE - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2013, 08:20 AM
JasonL's Avatar
Comp Cams 268HE
Anyone use the 268HE cam .454 / .454 lift in a 350 sbc?
I have one in a 355 with 9:1cr with camel hump heads, performer intake and 1.5 roller rockers.
I have a very smooth idle at 650-700 rpm with 16 degrees initial idle.
Anyone have this cam? comp says choppy idle...ha ha
Old 12-17-2013, 11:12 AM
techinspector1's Avatar
Wiki Edits: 326
I've used that cam in several 350 builds. Needs 9.5:1 SCR to operate properly.
Old 12-17-2013, 01:26 PM
JasonL's Avatar
Thanks
Thanks for reply. I just spoke to motor guy car is 9.3:1. It runs great and pulls super hard to 5500 rpm. Car has a 2000 still and 3.73 gears.
I am just curious why comp says choppy idle and its very smooth.
Old 12-17-2013, 02:07 PM
You most likely have it tuned well with proper timing, i wouldn't worry about it too much.
Old 12-17-2013, 02:12 PM
JasonL's Avatar
yes
it is tuned by a professional with a wideband. So yes it runs fantastic. Before it was tuned by him the timing was off and stuff and it had more lope to it. I was just curious why they say choppy and its totally not ha ha
Old 12-17-2013, 02:18 PM
Lopy/choppy same difference, you said it did have a lope before it was tuned well, so there you go, all i need to do with my mild cam is lower the idle & fatten up the idle & it'll be choppy, but the plugs don't like it.
Old 12-17-2013, 04:14 PM
Wiki Edits: 326
I could find lumpy in those cams by turning down the idle, but I certainly wouldn't describe them as choppy. It's not the first mistake I've seen in info from CompCams. If you want a little more from the motor, advance the cam 4 degrees. It will make more cylinder pressure.
Old 12-17-2013, 04:16 PM
Proud LOSER
Had one in a 355, at 6-700 rpm in gear had a decent sound, at 900idle was mostly smooth....ran great for what it was.
comp cams rachet ralph Engine 11 08-06-2010 10:20 PM
comp cams ddpecka348 Engine 24 02-14-2008 07:41 PM
Anyone try Comp Cams Nostalgia Cams ? super_silent Engine 13 11-22-2007 03:01 PM
Comp Cams 48 Burb Engine 3 05-26-2004 01:16 PM
Comp Cams 46_stvblt Engine 6 01-22-2004 09:02 PM
