comp cams 286 hydr. roller? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 05:49 PM
does anyone run comp cams 286hr roller cam? and how does it perform? does it have a lopy idle that everyone wants.
Old 03-13-2008, 02:48 PM
Re:comp Cam 286
Hi Know one else has said anything so l'll threw 2cents in! l don't have the 286 but l do have a 270H and a 280H and both of them are alittle lumpy more so the 280H but with your 286H you'll need to make atleast 9.5 compression same as the 280H ! Wife hates it but l like it!! Good pull to it! TROY
Old 03-13-2008, 03:35 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
There is quite a difference between a 286HR and a 280H they really wont act the same. The 280H is an aggresive cam which will rattle pretty good for a flat tappet but the 286HR is pretty middle of the road for a roller, if you want to be sure you have the aggressive tones you are looking for you probably will want the 300HR. However this will sacrifice your low end alot. I guess it is all about what is important to you.
However I think you will get a decent lope out of the cam. The higher the compression and the tighter the rings the more profound the lope will be.
Comp Cams, What a Joke! Don't order their products chrismac Engine 51 01-01-2008 10:04 PM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 10:34 PM
AMC Comp Cams roller tip rockers HELP Spiders Engine 8 01-30-2006 06:59 PM
comp cams hi-tech lite htl lifters 406 ss monte Engine 0 04-24-2005 05:40 PM
Roller cams MI2600 Engine 4 11-28-2002 07:40 PM
