Comp Cams grind 4-7 swap - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-24-2010, 09:59 PM
They seem to sound a little smoother. Look up 4 7 swap on youtube
Shane
If you do not want to register, fill this field only and the name will be used as user name for your post.
Lunati or Comp Cams valve springs? staleg Engine 5 01-21-2010 04:25 PM
Comp Cams belt drive / damper fitment SoCalJim Engine 2 07-31-2009 06:40 PM
confused about camshafts (FSB) pstrbrc Engine 9 11-30-2008 08:02 PM
Comp Cams? 76 CAPRICE Engine 13 11-14-2006 07:37 AM
Comp roller cams reliability in BBC Steam Roller Engine 1 11-02-2003 11:33 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
