Comp Cams Hardware/781 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 09:07 AM
Kraneking's Avatar
I am looking for some opinions on Comp Cams hardware/components and Manley valves. I am building a 489 c.i.d. and the foundation is a Gen VI GMPP block.
When I ordered the block, the latest casting, I was told that Mark IV heads will work because of the redesigned water jackets. When I looked at the decks everything seems to match up to the older heads so I had a good set of 781 castings done up. I don't care about the weight and compression will be at 9.75 max and she will only drink 91 pump gas.
The 781's have had good bowl work/machine work, larger 2.19 intakes, new hardened seats, new bronze guide inserts, Viton seals, Manley 11/32 stainless valves and Comp hardware.
Can someone answer the following questions please...
1. - Is the Fel Pro head gasket #Z1037 a good choice? (4.370 on a 4.280 bore)
2. - Anyone ever have trouble/issues with Manley valves?
3. - Anyone ever had trouble/issues with Comp hardware?
I know the questions about Comp and Manley are generic at best but I would like to here from some people that have used these parts on an engine like mine. I have used Comp stuff in the past and never had a problem but this is my first serious, complete engine build. All I have done before is swap springs, camshafts, etc.
Also, this engine is for a street driven car only. 3700 lbs, 4.11 rear, Super T10 (2.43 first gear, 904 steel case and mid-plate), radial tires always, and 5500 rpm max. I am trying to make as much torque as early as possible and keep the band in the low to mid range.
I assembled the heads at home and the machine work was done by one of the best shops here. I used all the recommended Comp components and spent hours getting the installed height within .010 of each other. Everything went together nice and all looks good. My cam choice is going to be the Comp XR264HR or the XR270HR.
I know this is a long post and I really appreciate any replies, answers, comments or suggestions.
Thanks everyone...
How good are pro comp cylinder heads automedics Hotrodding Basics 55 01-14-2016 02:19 PM
Question on Pro Comp Heads on SBC and intake matching y2k600f4 Engine 20 10-10-2012 06:14 AM
Comp Cams belt drive / damper fitment SoCalJim Engine 2 07-31-2009 06:40 PM
SBC Holley heads & Comp springs? v8hed Engine 8 07-06-2008 07:18 AM
Comp roller cams reliability in BBC Steam Roller Engine 1 11-02-2003 11:33 AM
