Comp Cams Magnum 280h vs xe274h - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-27-2013, 06:35 PM
Banned
Roller cams cost more and deliver more power and much better (reduced) wear. There's no arguing that point. Consider that all the oems switched to rollers on these engine types a long time ago, there's probably a good reason to consider it for your ride too.
I understand having a thin wallet. I also understand that it royally sucks when you have to rebuild a brand new engine when a cam goes flat.
I also understand that a basic 5.3l with a little work is cheaper and will run faster with better mileage... Sbc's are the new flat head ford. Done be surprised to beat by a lot of stock newer cars, not just a ZL1.
Hot sbc's still sound cool but they get beat quite often on the streets now.
  #17 (permalink)
Old 07-28-2013, 10:24 AM
I would use the old school 280H. Much less likely to go flat than the xtreme cam.
A 280H should pull hard to 6500 and will work well with your CR, gear, trans, and car weight.
I had good results with the 292H. Pulls hard to 7,000 rpm. 3.90 gear, T5 5 speed, 26" tall tire, 10.5 cr 350, 200cc iron eagle darts. Trapped at 120 mph in a 3000 pound car which takes around 400hp at the tires to do that.
  #18 (permalink)
Old 07-29-2013, 09:14 AM
Originally Posted by F-BIRD'88 View Post
The removal of lead from gasoline in 1971 was only part of the story of the the 70's era smog motor short valve
job life .. The other half of the story was the high exhaust temperature from the retarded ignition timing
and the twinned exhaust EGR ports in the smog heads like the 882. and 462624 head
The exhaust port and valves were forced to run a lot hotter on those motors in an attempt to burn off unburned hydrocarbons and make the old style pellet Cat converter function.
The exhaust valves and seats ran hot too. Hot exhaust valves and valve seats from retarded timng sinks the exhaust valves
These cars were notorious for starting grass fires and warping the exhaust manifolds from excessive exhaust heat. (retarded ignition timing) 60's era SBC exhaust manifold warping is almost unheard of.
now you know the rest of the story.
You do not need to pound a oil with Moly additive either . I use half the dose of the Molyslip E in my oil,
So 1 can lasts for 2 oil changes.
for my car . Excessive additive is not better. I still like the GM EOS too. It is now relabled as GM Engine break in additive instead of Engine Oil Supplement.
It is not a fix for cheap cam cores, cheap lifters or improper manufacturing method. Or improper install.
Thanks for the "Rest of the story", I cant remember the name of the radio announcer that said that line.
Would GM EOS or its new relabel be sufficient for use in my 283. I run Shell conventional 10x30. World some EOS protect the flat tappets/cam in my 283?
Or should I run a diesel oil such as Shell Rotella?
The only drawback to roller cams is cost, and perhaps their weight if you are spinning the engine at high rpm. They help with power and fuel economy. They do require a very hard core though. I have seen some bad stock Vortec 454 roller cams.
thanks
peace
Hog
  #19 (permalink)
Old 07-29-2013, 09:35 AM
Banned
Paul Harvey, and now his son, Paul Harvey Jr.
  #20 (permalink)
Old 07-29-2013, 03:11 PM
Banned
The SHell Rotella has had the Zinc ZDDP content rolled back now too. The 15w-40 Rotella is still dame good oil thou.
Find a oil that is designed for the old flat tappet cams.
Anything you now see at Walmart or CTC common off the shelf street motor oils is not going to cut it.
you now need something that is labled "not street Legal" or "racing oil" or
Amsoil Muscle car oil,, Brad Penn etc etc. There are many oils intended for "flat tappet cammed" engines, now, to choose from.
I am using the MolySlip E additive on my oil. (1/2 dose)
it is readily available, here.
a lot of racing or NSL oils have low detergents- so they're really not helping you out any. Kinda makes you wish you spent the extra $100 upfront and got a block with roller provisions- would have saved you a hell of a lot of headache.
  #21 (permalink)
Old 07-29-2013, 07:26 PM
yea the low detergent content sucks, hello oil changes at 1500-2000 miles
whatever, all of these dinosaurs we ride in only get driven once or twice a week
  #22 (permalink)
Old 08-05-2013, 12:56 PM
Thanks for all the input and thanks too for the lesson on motor oil. I have decided to go with the xe274h cam. The numbers look good on it, I guess we'll see when I get it all together. If it sucks, its only a cam and they change out pretty easy. Thanks again for the advice.
  #23 (permalink)
Old 08-06-2013, 09:30 AM
Disappointing about the Rotella 15W40 diesel Rotella.
Thanks F-Bird.
peace
Hog
  #24 (permalink)
Old 08-06-2013, 01:31 PM
Fire60, as it sounds like you are leaning to the flat tappet Comp Cam, before you go and order it I suggest you read this link to Comp Cams and see what extra it would cost for you to add this built in measure of safety to possibly prevent a cam shaft failure.
Pro Plasma™ Nitriding Process
Its a crappy deal that the oil companies are reducing the ZDDP as it sure won't do the older engines on the road or farm tractors for that matter any good. Anyway others who commented on the cam choice, throw out your thoughts on nitriding ....
  #25 (permalink)
Old 08-06-2013, 02:44 PM
vinniekq2's Avatar
In non roller cams I too have used Isky.The profiles in their catalogues really make sense.Isky can also offer any grind you dont see,just ask.
The only cams I wont buy again;wolverine,elgin
Choosing Gears To Go With A Magnum 280h Cam the82elco Transmission - Rearend 10 02-07-2013 03:43 PM
Possible Cam Number Comp CAms sloid magnum series nova327 Engine 1 09-11-2010 03:38 PM
comp cams magnum rollers sooper Engine 23 02-03-2010 01:47 PM
magnum comp cams jkingof9561 Engine 5 05-04-2008 02:50 PM
Anybody running a Comp Cam XE274H-10 stingraymax Engine 3 11-21-2003 08:50 PM
