Comp Cams Magnum 280h vs xe274h - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2013, 04:07 PM
Hey everyone. Im looking for a little help with cam selection. Everytime I talk to someone about the math I hear Charlie Brown's teacher.
I'm not looking for a super high HP number(I wont complain about one either), I'm looking for the car to be an absolute beast from as low as possible to about 6000-6500RPM. Its a Saturday night toy, not a drag car, but I also dont want to get beat by some 18 year old kid at a traffic light.
Here's what I've got:
350 .030 over 4 bolt
Speed pro l2256 forged pistons
stock crank and rods, rods resized crank polished rotating assembly balanced
Brodix race rite 200 heads port matched
going to use an edelbrock rpm air gap intake
edelbrock 750
compression(by my math)is about 9.85:1
M21 trans
4.11 rear
stuffing this in a '70 Chevelle
The magnum 280 and xe274 were the recomendations I got so far. The first from summit the second from comp. What do you all think of these two for what I want or is there something better out there?
Old 07-26-2013, 05:37 PM
Comp Cams K12-433-8 Retro-fit Hydraulic Roller cam and kit.
236 I / 242 E degrees duration @ .050"
.520" I / .540" E valve lift w/1.5:1 rockers
110 LSA
9.1:1 min. compression ratio.
2500 - 6000 RPM cam range
Beware of an 18 year old kid at a traffic light with a 2013 Camaro ZL1 with 580 HP V8.
Old 07-26-2013, 05:54 PM
Oh id love to go with a roller cam but its just not in the budget right now.
Old 07-26-2013, 08:09 PM
I currently have the xe274h with 10:1 compression and a rear gear ratio of 3.73
I freaking love it, Idles at about 900rpm and it sounds amazing
good midrange power from like 1600rpm and up in my engine
great torque too, in my particular engine it only likes being revved to about 5800 rpm max
Old 07-26-2013, 09:20 PM
That's right where is like to be as far as rpm. Like I said, I'm not building a race motor. With the low gears do you think I should go up a size for the cam or will that hurt my low end torque?
Old 07-26-2013, 09:37 PM
In my honest opinion the xe 274 was about as big a cam as I would ever want to go in a street driven car
if you're looking for a cam with streetability that gives you more power than the xe 274 you're gonna have to look at roller cams I'm afraid
bigger is not always better. it's nice have a little bit of the power curve below 2000 rpm
Old 07-26-2013, 09:53 PM
I'm with ya. I want it to move and shake whenever I punch it. That'll be mostly on the lower end. Thanks for input
Old 07-26-2013, 10:39 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I am running an XE274H in my SBC. 9.9:1 on Factory iron Vortec heads. Initial timing 26* and 35* total. Idles at 900RPM, makes 11" vacuum at idle. Runs my power brakes OK. I have 4sp manual trans and 3:73 posi. Truck is about 4,000 lbs. I love the cam, makes power all over. I was concerned it was too much cam for this heavy truck, but I think its great in the end. The 280H cam has slower ramps rates so it is not as sporty as the XE series.
Here is a good video to hear the idle sound. Note that I still had some carb issues at this time, and the linkage was right, not hitting WOT.
Here is the video that shows a lot more power output. At :07 you can see the rear end squat and tires break loose as the secondaries open. Carb is still lean in this video.
Old 07-26-2013, 10:47 PM
vinniekq2's Avatar
you are comparing a very small grape to another very small grape.
what mousefink said,at least use a roller cam,it will make more power everywhere in the RPM range.
Old 07-27-2013, 12:37 AM
Fbird, ill defiantly cc the heads. Thanks.
Surfer, what you got is exactly what I'm looking for. Smoke em thru second gear and then some. Thanks for all the input
Old 07-27-2013, 08:37 AM
You cannot get any camshaft that will make good power above 5,500 RPM without using high load valve springs. If you try that with a flat tappet camshaft and use no-lead pump gas, you are asking for a flat camshaft.
Save your money until you can afford to install a high performance roller camshaft and the appropriate high load valve springs. Then you can use 93 octane pump gas with out any problems.
Old 07-27-2013, 02:47 PM
The refineries started reducing tetraethyl "lead" (ZDDP) from all gasoline stocks following the 1970 Clean Air Act. Starting in the 1971 model year, American automakers started reducing valve spriing pressure in all their production engines in an attempt to prevent valve spring seat erosion and camshaft wear. . By 1980, ZDDP (zinc) was completely eliminated from gasoline and automakers redesigned the engines to use roller camshafts in ordeer to prevent camshaft wear along with the weak valve springs to reduce valve seat erosion. Roller lifters completely solved the problem of camshaft wear when using no lead pump gas. The factory roller camshafts are not radical high lift camshafts and can get by with weak valve springs. If high lift (over .470" valve lift) aftermarket camshafts are used, you must use higher rate valve springs or risk engine damage at high RPM and that is especially true with high lift roller camshafts.
Supercharged engines such as the engine in the 2013 Camaro ZL1 require higher valve spring pressure in order to seat the valves with the supercharger boost trying to keep the valves open. . Supercharged engines require high rate valve springs and induction hardened exhaust valve spring seats.
Old 07-27-2013, 03:07 PM
Old 07-27-2013, 03:22 PM
Xe274
That's what I am running. 383 stroker with 3.73 gears into a pick up. Cam has a grip of torque but I stuffed a Hughes 3000 stall into the turbo400. It is crazy power from start to 4800 rpm. I have never wanted to go any faster. Cam states power above that rpm but I don't need to go faster than 100 in my 30 plus year old truck. Running 15" rims 275 60 r15 8" wide. It rips thru first and hooks pretty well at second. My choice is the 274.
Old 07-27-2013, 03:56 PM
You are correct F-Bird, in addition, lead was used as a high pressure, high temperature lubricant which in addition to the points FBird already established, helped to prevent valve seat recession, or the "sinking" of the valve seat into the head. As the Gov. mandated the reduction of lead in on-highway fuels, the OE's had to start using induction hardened exhaust valve seats or valve seat inserts to combat the issue. CHevrolet was noticing valve seat recession to such an extent that the valve seats actually failed after only 24 hours(approx.) of dyno run time.
I have 70,000 miles on the 283 Powerpack that uses the stock flat tappet camshaft. I'm always worried about it since the ZDDP content was lowered in order to help to keep the catalysts from fouling.
I have heard good things about Moly type lubricants.
This same engine required the exhaust seats to be machined out and hardened inserts were installed for use with unleaded fuels.
peace
Hog
Choosing Gears To Go With A Magnum 280h Cam the82elco Transmission - Rearend 10 02-07-2013 04:43 PM
Possible Cam Number Comp CAms sloid magnum series nova327 Engine 1 09-11-2010 04:38 PM
comp cams magnum rollers sooper Engine 23 02-03-2010 02:47 PM
magnum comp cams jkingof9561 Engine 5 05-04-2008 03:50 PM
Anybody running a Comp Cam XE274H-10 stingraymax Engine 3 11-21-2003 09:50 PM
