If after fully researching this cam you still want to run it, the cam requires a lot of initial timing (20 degrees-plus) to allow the carb to be adjusted for a decent idle w/o the primary throttle blades being opened so far the carb is idling on the transition circuit. This will mean the distributor may need work to the mechanical advance mechanism to keep the mechanical advance from adding too much timing. An adjustable vacuum advance will be needed in most cases as well. There are many posts on this forum and elsewhere on these cams, you can do a search for more. Until then, these links may help: • Ignition advance • Cam installation • Adjusting the valves • Distributor installation • Valve train points to check |
thumper cam yes/no??
i think i'll heed what your not saying...dont sound like you like this cam for the street, so i'll think about a different cam??what would you reccomend as to what i'm looking for??steetable but would like a nice lope to it IF possible.i do understand i can't always get what i want both ways.
sooooo???thanks &happy cruisin!!
A cam with a narrower rather than a wider lobe separation angle (LSA) will have more lope. A later intake closing point will tend to increase the overlap and cause a lope, same thing for an earlier opening exhaust. Headers and a free flowing exhaust system will help the sound of a cam, stock exhaust manifolds like found on Gen 1 SBC engines inhibit the sound. Also, I'm not totally discounting the use of a thumpr cam. They have their place and as long as you're willing to give up some performance for sound, then it may not be such a bad choice for you. It's just that many guys feel that if they are going to live w/a cam that has less vacuum and a lot of lope, they will go all the way and run a cam w/as much performance to offer as it can. One thing about the thumpr cams is for the sound they have, the vacuum isn't all that bad. |
There are cams that will work well with a stock converter and a fairly stock engine, and still give that lopey idle, but not lose useable bottom end. Crane has a nice cam that is 272/272 duration, with .454" lift and a LSA of 108. It's good right off idle at 1500 to around 5800 rpm's. You'll be much happier with this than any of the Thumpr cams.
Summit sells the same cam under their brand name for a lower price, so you can save some bucks and go with their's. |
yeah??
sounds like the perferct cam for me.i didnt want to stick in something only to have one problem after another to deal with...what are your thoughts on "brand name" vs. "generic" if you will.dont mind saving $$$ at all.just dont want to have to go back into the motor 2 months later and do this all over again.reliability is uppermost in my mind..many years ago i built a 350 bored .030,4bbl,dual plane intake,headders,4 bolt main,"pink rods",true duals w/ the factory 327/350 hp cam.in a 75 camaro ,limited slip rear {you'll never believe this buts its true}a 2.56 gearset....also 350 trans w/shift kit.....burned not barked a mean 2nd gear {3rd if my ex-wife was driving and pissed off
}that set-up i was very pleased with.this time i want to step up 1 or2 notches. the cam you recomended sounds perfect for my needs!!!!already got the p/n written in my wish list.thanks for getting rid a headache i've for some time...i have agonized over this prob. for a long time..glad i accidently found this website !!!sorry for being so longwinded. nobody closeby to discuss this with....happy cruisin!!!!!!
Ronbuhg, you don't state what your truck setup is/will be but since you've said it will be street driven I'm going to make a few assumptions. I'm assuming a stock/near stock compression ratio, and you want a pump gasoline friendly compression ratio, so 9.5:1 or less static compression ratio (SCR). For a truck, which will be a lot heavier than the Camaro I would recommend a cam with a little less .050 duration than the ol' 327CI 350HP cam (even tho it's one of my all time favorites). That cam, and the 350CI 350HP cam, was designed for engines with 11:1 SCR, and both have a wide 114* LSA so they will idle smooth. With the lower CR's of the "smog era" engines, it really lowers the DCR (dynamic CR) so it loses a lot on the bottom, which is why the GMPP 350CI 290HP crate engine, with 8.5:1 and the ol' 350CI 350 HP cam, has a reputation as a slug til it's gets the revs up. I would stay with a milder duration cam, but with a tighter LSA as Cobalt327 recommended.
I'll recommend a few more modern cams for your truck. First, the grind commonly known as an "RV cam". EVERY cam company has this, or an almost identical grind. Look for .420/.440 lift, 204*/214* @ .050, with a 110-112* LSA. A little more lift and duration than the ol' 350CI 300HP cam, and pulls hard in a heavy vehicle like a pickup or RV. 2nd, one of the most popular grinds, EVER. The Comp Cams High Energy HE268, .458 lift, 268* advertised, 218* @ .050, 110 LSA 106 ICL. I imagine the reason it's so popular is precisely because it has the right combination on lift and duration to work with the millions of "smog era" SBC's, and has a bit of choppiness for some of the "cam music" that we love. 2 very popular cams for SBC's with "smog era" static compression ratio's (example 8.5:1 to 9.5:1) are the Crane 274HO6 (and versions by Summit and Elgin) and a grind I'll call the K1103 (Sold by Summit Racing as the K1103 although every cam company has this grind). These cams have mild .050 duration figures to maintain dynamic CR for low end power. They will work well with stock torque converters and "highway" gears, but will work even better with higher than stock stall converters and lower (higher numerically) gears. Crane 274HO6 grind, .450 lift, 274* advertised duration, 218* duration @ .050, 106LSA, 102 ICL Cam/lifter kit $209.60 at Summithttp://www.summitracing.com/parts/CRN-100072/ The 274HO6 is an equivalent cam to the ultra popular Comp Cams High Energy 268H, but is ground on a tighter 106* LSA. It has a choppy idle with mild 218* @ .050 intake duration. This cam is one of the grinds that Crane used to classify as "3/4 race". Summit K00172 (Same grind as Crane 274HO6 - supplied to Summit by Crane) Cam/lifter kit $133.95 http://www.summitracing.com/parts/SUM-K00172/ Elgin CL1785PK (Same grind as Crane 274HO6) Cam/lifter kit $99.95 at Northern Auto Parts http://www.northernautoparts.com/Pro...tModelId=17034 YouTube video of 274HO6 idling in Shaun's '73 Nova with stock Goodwrench 350, Performer intake, 600 cfm Holley carb, open headers. Nova has hi-stall convertor, 3.73 open diff (no posi), has turned 13.86 1/4 mile with drag radials http://www.youtube.com/watch?v=sDEthCakytU Summit K1103 (same basic grind as GMPP 350HO and CT350 circle track crate engine. Cam/lifter kit $99.95 at Summit. The "K1103" grind (.443/.465 lift, 214/224 @ .050, 112 LSA) has just slightly more lift and duration than the cam used by GMPP in the "350HO" (350CI 330HP) crate engine and the "CT350" (350CI 350HP) circle track crate engine. .435/.460 lift, 320*/324* advertised duration, 212*/222* @ .050 duration, 112.5* LSA. This is a little more "modern" split pattern cam, and has a wide flat torque curve, the idle is not quite as choppy as the 276HO6 but still has some choppiness so you can "hear the cam". The K1103 cam/lifter kit is $99.95 at http://www.summitracing.com/parts/SUM-K1103/ The 3 cams below are the same grind as the K1103. Lunati Barebones 10001LK - C/L kit $99.95 at Summit http://www.summitracing.com/parts/LUN-10001LK/ Elgin E-922-P C/L kit: CL-922PK $137.15 at Northern Auto Parts http://www.northernautoparts.com/Pro...ntoryId=114312 SpeedPro CS1013R C/L kit CL1013PK $148.61 at Northern Auto Parts http://www.northernautoparts.com/Pro...ntoryId=114312 Youtube videos with K1103: '70 Chev C10 with 350 http://www.youtube.com/watch?v=_K-XV3Yum8k 350 with noisy gear drive http://www.youtube.com/watch?v=K-M45...eature=related As for "name" versus "generic" grinds, the main difference is the label on the box and the price. Most all cams, no matters who's box it comes in, are ground by 3 cam grinding companies. The only cam companies, as far as I know, that grind all their cams in-house are Isky and Howards (both very good cams). The Crane 274HO6 part # is 10017. The last I knew Summit cams were supplied by Crane. The Summit part # for a cam/lifter kit is K10017 (looks kinda like Crane's number, huh?), but the part number for the cam only is 1785, the same as the part number for the Elgin boxed cam. Hmmmmmmm... Hope I didn't muddy the waters too much in your decision makin'! Ed Last edited by BigEd36; 05-16-2012 at 08:21 PM. |
I wont buy junk to put inside my engine, but the Summit cams are nothing different than regular Crane Cams in a plain white wrapper. All you're giving up is a box that says Crane. I've used a lot of them, and as long as I can look up the specs and crossreference it to the same Crane Cam, then I know it's good.
There are a few Summit cams that I'm unsure who makes them, as I don't find equal cams in Crane's catalog. I steer clear of those until I know who makes them. |
I knew the part #'s for those 2 cams 'cause a lot of short track racers in the "hobby" classes use the 10007 cam, guess I saw the "7" and got in a hurry. Sorry for any confusion this may have caused. Maybe the mods can correct the link in my post, I can't edit it now.
Ed |
| ? about the new Thumper cam from Comp. | streetmaster42 | Hotrodding Basics | 19 | 01-17-2012 01:45 AM |
| comp cams " thumper" roller cam | 67-4-fun | Hotrodding Basics | 3 | 06-05-2011 06:05 AM |
| comp cams | ddpecka348 | Engine | 24 | 02-14-2008 07:41 PM |
| Anyone try Comp Cams Nostalgia Cams ? | super_silent | Engine | 15 | 11-22-2007 03:01 PM |
| Comp Cams | 46_stvblt | Engine | 6 | 01-22-2004 09:02 PM |
