Comp cams took care of failing cam
For those who dont know, when I disassembled my turbo engine for the bearing failure I found that the cam lobes had premature wear. I ended up sending the cam back to comp for them to look at it. They listed many things that could have caused the failure and said they thought it was a break in problem.....which I dont think, but oh well.
Anyhow, they said they would give me a factory credit and I could pick any cam I wanted to replace that cam. I have decided to never run a comp cam again since I have had mulitple failures, but it is nice to know they took care of the problem. I guess I will order a common cam and stick it on ebay or something. If anyone needs a cam, I can get you one at a discount ![]() Chris |
are you sure the cam failure didn't have anything to do with the bunch of stuff that got into your oil?
K |
Nope, not sure at all.........it is possible I suppose.
Hey Chris watch this get dumped for advertising. j/k
It's good to see that Comp made good on the bad cam. Will they would let you credit that towards the cost of one of their roller cams? (for your S-10.) |
Hehe....did not ask about a roller cam, but I doubt it. They would likely give me the price of that cam as a credit to a roller. It would still cost me too much to fit my budget right now. I am going to try another flat tappet cam. I decide to go with a summit cam.....and not just for price. They were the only ones who had a cam close to the specs I wanted without having a custom grind. The grind I bought was almost identical to a custom grinder I talked to and also very close to what Cstraub recommended. Chris |
Summit Cam & Lifters
Summit = Crane = No problems (IMO)
But I would think twice about using the standard hydraulic lifters that come with Summit kits. Look at using the Speed-Pro HT 817R race lifters. I don't see them at Summit, but Jegs and Scoggin-Dickey have them. They have a heavy duty snap ring. In fact, it is not even a snap ring, but a very rigid clip. It allows for setting near zero lash and high RPM without the fear of the snap ring popping out. I wish I could find a picture on the web, but no luck. Good luck with your rebuild, Ed www.edgesz28.com |
Hmm? Bearing failure: Turbo: Worn cam
Chris, is there a way to check your oil pump? Maybe not enough flow/psi? That turbo is tough on oil with the additional heat it produces. Just a thought. I think its stellar that they will back it up. I would have thought they'd bailed... Jeff |
The bearing failure was because the machine shop did not brush the oil passages and I did not because I asked them to. Lesson learned the hard way. The turbo does add heat to the oil, but I run a thermostatic controlled oil cooler with a 1100 cfm fan mouted directly to it.
Chris |
NXS,
Like I said, it is possible for that to have caused the wear, but seems to me that the lifters would have shown some wear. Do you work for Summit or something? The cam I got is 234/234 dur. 488/488 lift with 114 lsa. It is about perfect for my engine, but, I wish it had a little more lift. Cstraub recommended more intake lift, but the custom grinder that camaroman7d recommended was recommending a 234/490 straight across so was dead on with them. That cam was close enough I think it will make alot of power. Chris |
sorry to hear again about you having to take that beautiful motor apart chris. i have heard alot about comp cam failure but every time i have heard about one they have replaced the cam for free. lots of posts, as i think i posted once already when you first said your cam went south, blame it on comp cams' red lube they supply with the cam. i threw mine out. i used good ol' clevite cam lube. now get this, clevite changed their formula to RED! so for all i know they started letting comp make their stuff-aahh!!! so i have no idea what will happen to my cam now till i find out if the comp lube is the same as the new clevite formula. just too much! other guys think it best to use stock rockers on break in and switch to 1:6's after break in. maybe it works maybe not, but it made me make a last minute change back to 1.5's before i tried to start my engine again.
I dont like the comp lube and dont use it. I like cranes lube.
Chris |
I like that cam, it should work nice and be very driveable...just watch the octane on the first couple of passes! Oh, and I don't work for Summit but i've worked on a couple of road race teams. When I sold the Summit cams I was working at a speed shop and we had the full SBC selection from them on hand at all times. Very popular(price) and very good with the dish tops
Comp was our #2 seller, more popular with the deep pockets and flat tops.
| Recent Hotrodders' Lounge posts with photos |
