Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - comp cams XE cams
Old 05-06-2009, 09:05 PM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
comp cams XE cams
i saw a thead where someone use one of the XE cams from comp and had all kinds of valve train noise, and then a bunch of guys replied with post, baching the XE line, i had plans on putting the XE274 cam in my 385 but now im second guessing my self, i dont want all kinds of crazy valve train noise that makes the motor sound like crap
is this a cam i should stay away from?
if so what are some other cams that will work well with a 385, cast crank, scat rods, kb 18cc dished pistons, 0 deck with 200cc/ 64cc/ 2.02/ 1.60 heads?
the car is 3450lbs with driver, street/strip, 4.10's with beefed up 700R4
