Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - comp cams XE cams
Old 05-06-2009, 11:05 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Originally Posted by 4 Jaw Chuck
I'm curious as to how a camshaft of a different make will cause noise that others don't?
Sounds like hooey or incorrect setup to me.
There has been internet propaganda that says Comp's cams are more likely to wipe flat because they use a softer core casting. An improperly broken-in cam would be more likely to wipe and cause noise, but I think its the whole Ford/Chevy debate. Someone installed a Comp cam, it wiped a lobe causing a tick, and the rumor started.
Many cam companies source their cams from the same foundry anyway and then just grind them to their own specs.
The point is, find the cam you want with the specs you want, and break it in properly. They will all serve you well... if you pick the right one
