Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - comp cams XE cams
  #23 (permalink)
Old 05-07-2009, 10:07 PM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
Originally Posted by ap72
the head and block are MUCH hotter than the push rods
And you may have problems from too much preload, try it with 1/8 turn and see what happens. I've set them with DNN when the engine was hot.
OK I can see your point on the expansion note. Yes I am going to try it with as little preload as possible maybe the 1/8th you mention thanks.
