comp cams XE cams - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-04-2010, 08:49 PM
I have a 94 chevrolet truck with a TBI injected 383 with the Comp Cams XFI & lifters. I have had valvetrain noise issues since day one. Ticking noise/sewing machine noise that seemed to get worse when the engine was warm. I first adjusted the preload at 1/2 turn. It was quite when the engine was cold & then slowing start making the sewing machine sound. Then I readjusted them to 3/4 turn but the noise was louder so I backed them down to 1/2. The noise was never there when the engine was cold. Then I found this http://www.compcams.com/v002/Instruc.../COMP4-115.pdf. I adjusted them again but at 1/8 turn. No noise. Some mornings I will hear one or two that will tap for about 3 seconds. I will make sure that I read the instructions first from now on. I hope I didn't mess anything up. Only time will tell.
  #47 (permalink)
Old 04-05-2010, 01:44 AM
New Member
comp cams XE cams
comp cams XE cams
--------------------------------------------------------------------------------<a href="http://www.ecplazazone.com " title="连接名"><img border="0" src="http://图片地址" width="862" height="266" alt="图片名注释">图片名</a>
图片代码
i saw a thead where someone use one of the XE cams from comp and had all kinds of valve train noise, and then a bunch of guys replied with post, baching the XE line, i had plans on putting the XE274 cam in my 385 but now im second guessing my self, i dont want all kinds of crazy valve train noise that makes the motor sound like crap
is this a cam i should stay away from?
if so what are some other cams that will work well with a 385, cast crank, scat rods, kb 18cc dished pistons, 0 deck with 200cc/ 64cc/ 2.02/ 1.60 heads?
the car is 3450lbs with driver, street/strip, 4.10's with beefed up 700R4
  #48 (permalink)
Old 04-05-2010, 09:13 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Was this preload procedure done to 1/8 turn with the engine hot or cold? thanks
  #49 (permalink)
Old 04-05-2010, 09:39 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by gongsi1234
comp cams XE cams
图片代码
Your static compression ratio is 9.75:1, so most any cam with around 225 to 235 degrees duration @ 0.050" will work well. Personally, I don't like the extreme cam grinds as I feel they apply excessive pressure at the lifter/lobe interface. I also don't care for increased ratio rocker arms for the same reason.
Here is an example of a hydraulic flat tappet cam that I might choose for your motor, that is if I were going to use a flat tappet cam. I refuse to use anything less than a roller camshaft any more due to all the flat tappet failures I see and hear about....
http://www.summitracing.com/parts/HRS-112031/
A roller hydraulic like this one might be a close choice....
http://www.summitracing.com/parts/HRS-110325-08/
WARNING: you should always counsel with the technician at the cam grinder's place of business for a recommendation before you purchase a camshaft for your motor.
  #50 (permalink)
Old 04-05-2010, 04:18 PM
6426yy's Avatar
I'm running a Comp 4x4 XE 270 cam in my 454 and it is nice and quiet.... The valve train anyway.
  #51 (permalink)
Old 04-07-2010, 06:15 AM
It should't make a differance with hydralic lifters. I adjusted them with the engine cold. I used the #1 firing, rotated the crank 360, & then adjusted the rest.
  #52 (permalink)
Old 08-14-2012, 10:40 PM
Cridder's Avatar
Last journal entry: 310 Small Block Chevy
BBC ex268
Originally Posted by curtis73 View Post
I like comp's cams. I have heard all kinds of comp bashing but I assumed it was a Ford vs Chevy type of argument.
I have a Comp XE268H in my BBC and love it.
Im running the same cam in my BBC 461 with heavly reworked 049 heads and big tube headers and i dont think it makes as much power as the 270 magnum that it replaced.
Im not so sure the 268 is the best choice for free flowing heads and 2 1/8" headers as i think it may be over scavinging with the much longer exhaust duration. the 268 makes 488 horse in a 454 HO crate motor, i should have 500 horse but i wonder.
What are you running for heads?
  #53 (permalink)
Old 08-15-2012, 01:09 PM
cridder,
First, note the date on the thread. It was "dead" before I ever came around here... (:-
XE268H has a little less duration than 270H. BBCs have exhaust ports that could be considered a little TOO "good" for the intake. That is, the balance of flow is a little lop-sided to the exhaust. So, it goes to follow, a cam with a little more intake duration and less exhaust duration WILL make more power.
That said, the XE cams (the smaller ones like the XE268H) are more for "low compression" drivers. The XE268H will work well in a 427-up with a stock torque converter. These cams are for a different purpose than the Magnums. We DID build a 396 a few years back with a solid roller XE grind. A 3,700 lb,. Chevelle went 12.10s with it. Oval ports, 92 octane. Good runner!
The point? XE cams have their place in the "pecking order". Good stuff when used "as intended".
Jim
comp extreme energy cams 86SSman Engine 10 03-12-2010 11:12 PM
Crane vs Comp Cam's 70 nova Engine 7 05-07-2009 07:49 AM
confused about camshafts (FSB) pstrbrc Engine 9 11-30-2008 08:02 PM
comp cams endur-x roller lifters 406 ss monte Engine 1 10-29-2007 03:15 PM
Comp Cams 46_stvblt Engine 6 01-22-2004 09:02 PM
