Comp Cams XE268 chevy cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2008, 07:02 AM
I am thinking about buying a comp cams XE268 for my mild 350 chevy. I would like to hear any info from anyones experiences with this cam and If you liked the result that you had with the camshaft. Any replies would be great. Thanks
Old 08-30-2008, 07:51 AM
the "results" depends on the whole car and motor and drive train combo!!!...
car wt/CR/rear gears ratio/tranny/etc/etc....
all the cam brands make a version of the 268, contact them and give all of your cars details to determine the best duration for your combo and how you use the car....
to me,
it's the definition of the best "all around" performance street/strip cam,,,,,excellent normal driving street manners, lot's of wow when you mash the pedal,,,,relatively low total engine/drive train parts cost to make it work excellent....
here's a link to some comp cam's dyno results for various durations.....
click on each to read the performance details and motor parts build....
http://www.compcams.com/Technical/DynoSheets/
Old 08-30-2008, 01:21 PM
MI2600's Avatar
Member# 3287
I got one in my 406 with Vortec heads. Good performance. Slight lumpy idle even with more cubes. But, it's the third one. The first two lost lobes. My fault, their fault?
Old 08-30-2008, 01:31 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I used a 268 in a 9:1 350 several years ago and was pleased with it. As I remember, it was the magnum, not the XE. I just can't see the need to jerk the valve open and slam it shut with the snappy valve action of the XE and prefer longer ramps. The cam has enough tragedy to contend with, without being asked to work harder than necessary in my opinion.
Old 08-30-2008, 01:48 PM
I have to agree with techinspector1. The added wear and stress on the valve train isn't worth the extra few HP they put out. If it was a race engine it would be another story but this cam is pretty mild and there are lots of other cams that would probably last twice as long and make within a few HP.
Jordon
Old 08-30-2008, 01:53 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I have one in my nova and it sounds real nice. Its only a target master motor with a rpm intake and 600 carb. I've had it for 4 years now and its my daily driver. With a stock stall convertoer it would try to pull the through the brakes when it was cold so I installed a 2400 and no more problems
Old 08-30-2008, 01:59 PM
I have one in a 383 SBC with Trick Flow heads, 10 to 1 compression, an Air Gap intake, and 770 Street Avenger, etc. It's a sweet cam in my book. It has lots of low end, more than my tires can handle, and a decent top end. It starts up nicely, is very driveable, and will run in the high 12's. Check out the dyno figures on the Comp Cam web site.
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
any one use comp cams dual energy cam before??? oldschoolmudman Hotrodders' Lounge 0 09-07-2007 07:41 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 08:22 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Big Block chevy cam help deuce_454 Engine 4 05-20-2002 12:15 PM
