comp extreme energy cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2002, 01:58 AM
New Member
Post comp extreme energy cams
Has anyone used comp cams extreme energy cams? I know the magnum cams are ground 4 degrees advanced so you can install them "straight up" and still have great performance, but are the extreme energy cams ground this way or do they need to be degreed? <img src="confused.gif" border="0">
Old 03-29-2002, 04:52 AM
New Member
Post
Geeze, talk about good timing...so to speak. I am holding in my hands an xtreme energy comp cam (249-cl12-238-2). The instructions mention that it comes 4 degrees advanced...out of the box.
Is that what you needed?
Old 03-29-2002, 05:58 AM
New Member
Post
Thanks, that was exactly what I needed to know.
Old 03-29-2002, 06:41 AM
Post
that block I am setting up has one, and the machine shop told me it was already advanced 5 degree's.
Old 03-29-2002, 07:01 AM
New Member
Post
Solowookie, your shop might be using a guage apre's install to determine that....much more accurate according to what I read. I'm just giving the numbers off the literature. Cool.
Old 03-29-2002, 08:44 AM
Post
I did the block assembly myself, but they said they've had people do their assemblies, and ask why their vehicles ran like crap; come to find out they had advanced their cam when they installed it, and ended with their cam advanced too much.
Old 03-29-2002, 03:13 PM
Post
Install it "straight up" in relation to the bolt holes and you'll have no problems.
Old 03-29-2002, 03:20 PM
F-1Rodder's Avatar
Post
All cams are ground for straight up installation. You change the mfr's. recommendation because you want to capitalize on something like better low end torque or more high end power. Any time you have a question like the one you just asked, go straight to the manufacturer's help line and ask. Its free and they know the answers. Good luck and use lots of assembly lube and be sure to follow the mfr's break-in advice. Cams are not pressure oiled at the lobe, so the worst thing you can do is to idle it during the first few minutes of running. They would get hot, ruin the cam and ruin the lifters.
Old 03-30-2002, 05:29 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
Go with the manufactures recommends. They grind the cams 4* advanced for ware of the chain. Put the crank stright up and the cam stright down. Thats what they have on their spec book.
If you go to their site they have all the info that your asking, plus more, great info.
site is compcams.com
Good luck
Luv the smell of NITRO in the morning.
Old 03-12-2010, 05:30 PM
Show me the money !
Comp xr270
Yes. Yes. Yes. Just put mine in straight up and I have a monster. #12-422-8
XR270HR-10. Call Comp Cams tech. I did about 5 times. They are great.
Old 03-12-2010, 11:12 PM
techinspector1's Avatar
Wiki Edits: 326
To find out how much a cam is advanced, deduct the intake centerline from the lobe separation angle.
Example:
intake centerline 106
exhaust centerline 114
lobe separation angle 110 (106 +114 divided by 2)
110 less 106 = the cam is ground 4 degrees advanced.
