comp ratio ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2012, 01:19 PM
comp ratio ?
Ok I used a cr tester and on my engine it said it had 9.1 to 9.2 that is off Fromm what everybody kept telling me just wondering what ppl think and if it is around what I said what kind of gas would I have to run thanks to any
Old 12-06-2012, 01:27 PM
WDCreech's Avatar
Grumpy Old Goat Herder
What kind of compressin tester tells the compression ratio?
Bill
Old 12-06-2012, 01:29 PM
delawarebill's Avatar
bill u took the words right out of my mouth..
Bill
i agree with u...
Old 12-06-2012, 01:51 PM
Sorry I meant compression ration calculator
Old 12-06-2012, 02:13 PM
vinniekq2's Avatar
i would use gasoline that does not contain ethanol
Old 12-06-2012, 04:14 PM
im runnin a stock 400 with vortec heads on it the head gasket crushed hight is .039 and im runnin just a comp cam xe256
Old 12-06-2012, 04:58 PM
-22 cc and 64 cc
Old 12-06-2012, 05:55 PM
Im not lookin to really do anything else I just wanted to know if that seemed right BC ppl kept tellin me like 9.6 to 9.8
Old 12-06-2012, 06:14 PM
Yea I used one that I had to put that in and got 9.1
Old 12-06-2012, 06:21 PM
comp ratio
Using United Engine & Machine Co. Incorporated your Static Compression is 9.199 and your DCR is 7.128. If you ever want to bump up your compression all you have to do is use the .015 steel shim head gasket. This will give you 9.664 and 7.476.
Old 12-06-2012, 06:40 PM
techinspector1's Avatar
Wiki Edits: 326
Using 9.2:1 SCR and an intake closing point of 32 degrees ABDC plus 15 for the calculator, DCR would be 8.262:1 and should make good power and work really well on pump gas.
I have no idea what intake closing point you used, but on Comp Cams, the intake closing at 0.050" is not published. You have to figure it yourself from the 0.050" duration and the intake centerline.
12-234-2 - XTREME Energy
Old 12-07-2012, 07:41 AM
comp ratio
Here is the specifications on the Comp Cams XE256H. 12-234-2 - XTREME Energy You are right the intake valve closing is 32* at .050". Not paying attention I used the valve opening at 6*
Old 12-07-2012, 12:22 PM
I ran this through my Excel based SCR and DCR calculator getting 9.19 Static and 8.055 Dynamic.
Feed data some assumed
- 400 inch stock bottom end
- 4.125 bore
- 3.75 stroke
- 5.56 rod
- Deck clearance .025
- Head gasket .039 compressed
- Piston dished 22 ccs
- Head Vortec 64 ccs
- Cam XE256H intake closed at 55 degrees ABDC, Intake at .050 inch 47 degrees after ABDC, calculation used is based on average Hydraulic Intensity calcuated for when intake is still open at .006 above the seat as 52.2 degrees ABDC, the apparent stroke is 3.23 inch.
Looking at this from a cam data distribution stand point
When intake is closing at .050 above the seat event is 47 degrees ABDC this would make a stroke length of 3.325 with a DCR of 8.26 to 1.
When intake is fully closed the seat event is 55 degrees ABDC this would make a stroke length of 3.168 with a DCR of 7.919 to 1.
A Vortec head can take a little more compression even on the larger 400 bore, as was previously stated by hcompton this can be boosted a bit with a thinner head gasket where a .015 gasket would boost the SCR to 9.66 with the DCR running in the ranges I calculated of 8.317 when closed, 8.44 at .006 off the seat, at .050 the DCR would be 8.68. So simply changing the assumed .039 composition head gasket to a shim styleis good for nearly a .5 to 1 increase in the DCR.
Bogie
Old 12-09-2012, 06:46 PM
Would doing that increse my power noticeably
Fuel octane for comp ratio. Holdon Engine 5 02-21-2012 03:02 AM
comp ratio conundrum Chevysrule454 Engine 3 07-03-2010 06:32 AM
Comp.ratio conundrom Chevysrule454 Engine 1 07-03-2010 12:44 AM
comp ratio bigtim Engine 3 07-15-2006 12:22 AM
Comp ratio and boost? HemmiGremmie Engine 2 02-20-2005 07:31 PM
