Comp Roller Tip Rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2005, 12:40 PM
wickster's Avatar
I purchased a set of Comp Cams Roller Tip Rocker Arms (1412-16) for my 350 Chevy & Performer RPM Heads.
Can anyone tell me if short vavle covers will fit?
Old 02-03-2005, 12:52 PM
johnsongrass1's Avatar
Race it, Don't rice it!
They will.
Center bolt covers wont though.
Old 02-03-2005, 03:41 PM
Chopper64's Avatar
Tired old shiftworker
That sucks...I have a set of standard size center bolt after market valve covers and have not put the motor together yet. I'm using the roller tips so now what do I do? I thought these would fit but maybe I'm wrong. Anybody else use these with center bolt and whats the cure for this problem?
Old 02-03-2005, 03:55 PM
A few racer buddies have tried it before. They run the centerbolt to perimeter bolt adapters. They use stud girdles too.
Old 02-03-2005, 03:58 PM
302 Z28's Avatar
GM Performance Parts makes an adapter that allows you to use the traditional two bolt valve covers on the center bolt heads. I think they are around $150.
pic at http://www.sallee-chevrolet.com/GM_V...24502540gm.gif
Vince
Old 02-03-2005, 04:17 PM
stepside454's Avatar
I had a set with standerd hight centerbolt valve covers, wasnt a problem, they were aftermarket cast aluminum..maybe they are a tad taller....also I had the Vette L-98 aluminum heads...Im thinkin now maybe the rails are taller on those
Old 02-03-2005, 05:05 PM
I have a set of Pro Magnums on my 383 and standard aftermarket cast aluminum center bolt covers. The only problem I had was the baffle/shroud around the PCV port. Had to bend it inward to keep it from hitting the rocker arm.
Trees
Old 02-03-2005, 05:22 PM
lluciano77's Avatar
That sounds like an oil leak waiting to happen.
I wish the aftermarket Chevy head manufacturers would make a head with the Ford valve cover bolt pattern. The could easily cast a few extra bosses around the bottom. They could also make valve covers to match. It wouldn't be hard, and it would eliminate a lot of headache for us gearheads too. They could even do it so you would be able to drill out your existing valve covers.
Old 02-03-2005, 06:47 PM
Chopper64's Avatar
Whew. Well I feel better now. Mine are the after market cast aluminum that I thought were a tad taller then stock. Thanks guys for the input. You made my day...
Old 02-04-2005, 05:01 AM
Last journal entry: PICTURE TEST
rocker arms
I ran the CC roller tip rockers on a standard set of vortec heads with stock steel covers with no issues.....
keith
