Compatible harmonic balancer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2012, 06:03 PM
I'm building a 73 Gran Torino as a mild sleeper. I'm having trouble finding a harmonic balancer to replace the old one. My parts guy found one for a 93 F150 and it looks the same but the counter weight is a different shape. The 351W and the 302 are all externally balanced basically the same right? So as long as it was for a 351W it should work right?
Old 12-14-2012, 07:48 PM
BOBCRMAN@aol.com's Avatar
No, Fords use at least two differen't balance factors for external weight. Maybe a Ford guy will see this post and give you the specs on what is interchangable.
I know in my parts replacement book there are several pages of different Ford balancers.
Here is a short partial list Silver Seal Products V8 Engine
Old 12-14-2012, 10:25 PM
techinspector1's Avatar
Wiki Edits: 326
It's unclear whether or not you have an old damper. If you do, send it back to these guys to be rebuilt. If you don't have an old damper, buy a rebuilt unit from them.
Damper Doctor Online - Your source for Harmonic Balancers, Motor Mounts, & Drive Shaft Supports
Old 12-15-2012, 12:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need a 28 oz imbalance damper if you are running a 351W. All the production 351W engines use this.
Which harmonic balancer? Madmax305 Engine 1 11-28-2010 11:36 AM
harmonic balancer hersch710 Engine 10 07-02-2008 04:08 PM
HELP !!! harmonic balancer ONEGALONLY Engine 3 05-07-2007 08:22 PM
Harmonic balancer 57halfton Engine 5 12-13-2006 12:09 AM
Harmonic Balancer '67Pony Engine 8 09-12-2003 07:57 PM
