CompCam LS6 #11-670-4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 05:55 PM
Is the lobe separation the only thing that gives you the
cam sound? A buddy has a Lunati cam with a 108 deg lobe sep
at that thing sounds pretty beefy plus it goes like a bat out of hell.
I was this CompCam I list, but don't want to be disappointed with the
sound of it. I have a std trans so vacum is no issue. This LS6 cam says
it has a 112 lobe sep with different intakes/exhausts dura and lifts.
Is this a good one for my 427?
thanks
Old 10-17-2008, 06:10 PM
F-BIRD'88's Avatar
Yada Yada Yada
That comp Nistalgia cam #11-670-4 is a hyd cam and is a good bit milder
Less duration than the origional GM 427-425hp L-78 454-450hp LS6cam.
The origional GM cam had 284-284 @.020" 242-242@.050" and .520-.520" lift 114LSA
The idle sound is a combination of the duration and overlap and LSA.
Your BBC will make more power with a solid lifter cam like the origional GM LS6 (a very sweet street cam) or Comps
"Magnum Muscle" replacement. Comp #11-551-5. If you want the "real deal" sound of the origional LS6 and improved power over and above the GM LS6 cam then this comp 11-551-5 cam is the one you want. The 11-670-4 is not even close.
A hyd cam will not sound the same or make the same power as a solid lifter cam at idle or under power. real high performance BBC's use a mechanical camshaft. This cam will ahve the sound and performance you are looking for.
11-551-5 cam card
11 converter with 2.73's FiveFeezy Transmission - Rearend 0 05-04-2006 01:32 PM
LS1 & LS6 questions. Jared Engine 2 02-18-2006 10:10 AM
Must 11 V/S T'bird Rack 1940chevy Suspension - Brakes - Steering 1 06-14-2005 03:16 PM
9 to 1 compression or 11 to 1 compression. What is the best? firewood Engine 5 09-22-2003 10:12 PM
advancing the timing on a Chevelle LS6 Quarter mile killer Engine 0 09-06-2003 12:07 PM
