compcams timing card - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2007, 02:50 PM
Im trying to degree the cam on my sbc. The card says when the exhaust opens and when the intake opens, etc. Are those numbers (in degrees) for when the lifter is at .050" lift? Because all of my degrees for when the intake and exhaust opens are around 10-15 degrees off.
Old 10-28-2007, 05:07 PM
ericnova72's Avatar
More for Less Racer
compcams degee-ing
Yes. those numbers are at .050" lifter rise.
Old 10-29-2007, 01:16 AM
papa_clutch's Avatar
power hungry
did you find true top dead center first? put your piston stop in and turn the engine clockwise untill the piston hits the stop, record the number, turn it counterclockwise untill it stops, the number should be the same, if not adjust untill it is equal on both sides. Also where do you have your indicator measuring off of?
Old 10-29-2007, 06:53 AM
engineczar's Avatar
That number may or may not be @.05 it will say so on the card. Some cards state both @.05 and @.006 lift numbers. What cam are you using and what numbers are you getting?
BSE Racing Engines
Old 10-29-2007, 11:52 AM
Last journal entry: PICTURE TEST
cam
Yea what enginecar said...
Plus, add the 2 numbers you are getting with your degree wheel +180 and it will equal your duration number @.050 if it does not then the card is giving .006 or something else for valve events.
If you want to know the .050 numbers in degrees take the duration @.050 and divide by 2 then subtract the cam LSA and that will give you the valve open event in degrees. then take that number subtract it from the duration @.050,subtract 180 and that will give you the closing event in degrees...
I will commend you for checking the valve events over just the centerline method.
Keith
Old 10-29-2007, 04:19 PM
Jmark's Avatar
Keith
HuH???????????
Old 10-29-2007, 05:30 PM
cam
Sorry Mark, i forgot you old guys are hard of hearing..L.O.L.
As an example,,,,Crane cam 967601
The card gives the valve events @.050 1 deg BTDC and 41deg ABDC this cam has a duration of 222 @.050 and a LSA of 110
So if you only had the duration @.050 and the LSA and you wanted to know what the valve events are,,,,you would take the 222 (@.050) divided by 2 = 111 then subtract the 110 LSA = 1 (thats the 1 deg BTDC from the above line) then take the 222 minus 1 = 221 then minus 180 = 41 ( thats the 41 deg ABDC) number from the above line.These are you valve events @.050 for that cam.
Keith ( not a carb guru but knows some cam stuff)
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 01:51 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 05:26 PM
Timing problem - Help MTMike Engine 1 11-13-2002 02:07 PM
