competition enginnering rear shock crossbar questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2007, 09:59 AM
dawg's Avatar
NAVY VETERAN
installed yesterday according to instructions.
in a 69 camaro you use the bolt hole for the rear end snubber to correctly locate the crossbar.
there are 3 holes ?
the piece fits in but the inner edges are about 3/8 away from the frame?
outter edges contact the frame.
ill snap a few pics in the near future once i get home.
Old 04-03-2007, 05:09 PM
dawg's Avatar
NAVY VETERAN
here are some pics
Old 04-04-2007, 07:32 AM
dawg's Avatar
NAVY VETERAN
anyone?
cmon someone did this kinda thing im sure?
Old 04-05-2007, 05:35 AM
dawg's Avatar
NAVY VETERAN
sigh
Old 04-05-2007, 06:56 AM
Sorry .... never used one like that. Have you tried calling Moroso/Comp eng ?? see what they say??
Old 04-05-2007, 07:50 AM
dawg's Avatar
NAVY VETERAN
emailed them and they are slower than snail crap.
ill call tomarrow for sure
Old 04-05-2007, 10:11 AM
powerrodsmike's Avatar
Wiki Edits: 161
They have some vague instructions. ( I went to the website.)
That multiple fit kind of stuff never fits anything just right.
They will tell you that they had to allow for dimensional variances in production, and thats why you get a 3/8" gap on the inside.. ( don't think I haven't heard that one a hundred times)
See if the shocks line up with clearance for suspension movement, if all is ok it can install there. Try to duplicate the original shock placement if you can.
Fill the gap between the crossmember and frame with with a piece of plate thick enough to close up the gap some. I like to leave a small gap to fill with my mig when I do stuff like that. It makes a nicer looking weld. Cut the center out of the plate if weight is some kind of issue.
Or just clamp it down close and weld it. That's how some guys would do it. It doesn't need to be welded all around anyway, just the ends would be fine. ( I wouldn't do it like that, I'd make my own crossmember that fit)
Later, mikey
BE different....ACT normal.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
Rear Gear Ratio questions!! dastone Transmission - Rearend 2 01-04-2007 11:15 PM
8.8 rear questions mike bryan Transmission - Rearend 2 05-19-2003 04:38 AM
10 bolt rear. several questions grizzly Transmission - Rearend 2 04-04-2003 01:37 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
