Completely pointless - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2013, 07:26 PM
cal1320's Avatar
My distributor, that is. I have been running points for the past few years, and haven't had any trouble with them. That being said, I wanted to change to electronic. But, I wanted GM dependability and availability. No MSD, pertronics or unilite. Problem is the HEI wont clear the firewall. New small cap HEIs from china are out of the question. So I built my own. I started with a points and an HEI and stripped both down. This included removing everything off the shafts as well. Then taking the necessary HEI parts and reinstalling on the points distributor.
Once everything is mocked into place the rotor needs to be phased. Tack weld in place and final weld.
This gives you HEI reliability with no firewall issues. And the module is easy to replace if the need arises.
ID:	73781   Click image for larger version
ID:	73782   Click image for larger version
ID:	73783   Click image for larger version
ID:	73784   Click image for larger version
Old 05-05-2013, 07:35 PM
life is a temporary assignment
did you run the car yet ???
Old 05-05-2013, 07:37 PM
cal1320's Avatar
Yes, runs great. Module is mounted to a heat sink with the thermal paste to keep it cool.
Old 05-06-2013, 05:23 AM
HEIDI from points
Thats something I'd like to try. Do you have any more info on how to set up the point dist. And the different parts to swap? PM me if you want. Thanks.
Old 05-23-2013, 09:00 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Where is your pick up coil from the bottom of the hei ,,,does the vacumn advance work ,is it adjustable .I like the looh of the small base dist.
Old 05-24-2013, 05:58 PM
LATECH's Avatar
Way cool.
Fact is stranger than Fiction
hi not completely new here warlock1980 Introduce Yourself 0 10-12-2008 07:08 PM
And now something completely different. Hippie Engine 1 08-27-2007 07:16 AM
pointless distributer for 52 chev. 235 rustychevy Engine 5 10-02-2006 08:12 AM
And now for something completely different Centerline Hotrodders' Lounge 18 03-01-2004 12:03 PM
