Completing a 305
First order of business: No, I don't want a 350.
This will be my brother and I's first engine build, a bonding experience! I got the block/heads/cam/intake for free. All I need are pistons and rods, right? The thing is, I'm new and don't know the voodoo behind matching these things together. All the guy knew is that it was an 80's model. I know I can look up the heads/block casting numbers, but what about the cam? And once I know what they are, how do I pick the proper pistons? The idea behind this build is a low-budget learning experience. I bought How to Rebuild a 350 (I figure it can't be too different) and I'm googling things, but it's nice to hear from a real person. |
tI rebuilds like any small block. My 305 has the performer cam and intake. Refreshed yard 906 vortec heads. Modded qjet and summit 9006 headers. Really happy with it. The 3.73 rear gear and 3000 dymanic stall help move the full size truck. It is no racecar but fun to drive.
The package makes the whole deal. Pick parts that work together. Everything trades off at some point. A 350 is much stronger, but if it just for fun.. |
But if the cam is used, do not reuse it- even if it comes w/lifters. The original lifters have to be kept on the same cam lobe they were broken in on, so the chance of them having been mixed up is too great to risk ruining a rebuild by using an old cam and having it fail. And you shouldn't use new lifters on an old cam, either. Besides, the cam is too important to be left to chance, and a new cam (reground, stock specs) can be bought for as little as $14, plus the cost of new lifters. A performance cam and lifter set from Summit is a good buy at $100. More on breaking in a new cam is here. The pistons are chosen to give the correct compression ratio w/the heads you will be using. Chances are, you will be using cast flat top or possibly dished pistons w/4 valve reliefs- they're the most common budget pistons. They also have to match the cylinder bore diameter. The pistons also have to provide the correct quench distance. W/the SBC engine using a 3.48" stroke crank and stock length rods (5.7"), the choices are a compression height of 1.56" (stock) or 1.54" ("rebuilder" pistons). More on this in the link above. Some suggested reading material is here. Last edited by cobalt327; 06-11-2012 at 01:14 AM. |
Also, thanks for the links. I'll do some heavy reading. The cam I have looks in marvelous shape, but that could be oil/gunk/untrained eye. If I clean it up, can I tell for sure if it's used or new? Will the rounded lobes be obvious? Double Vision: Thanks for giving me hope that it won't just be a 150 hp engine passed by civics! I'll return with pictures of everything. Thanks guys |
my suggestions would be to go onto amazon.com and look up books on how to rebuild chevy small blocks, David Vizard and SA design make some very informational books. then try to find a book that refrences the 305 exactly. give these books a good look, before you go too far.
good luck to the both of you. |
So, I'm putting the cam aside and just going to get a cheap new one. Maybe I'll even go with that link you posted!
Here is what I have: Block: 14093627 305, 2 bolt, roller cam, 1-piece rear seal Crank: 14088526 (I'd swear it says 528, check out the picture, but after extensive googling, a few other guys had the same problem and concluded it was an error in the mold) 305/350, 3.48 inch stroke, 2.45/2.10 journal, cast iron, 1 piece rear main seal Heads: 14102187 305, 1.84/1.50 Valves, 58cc Now that I know all of this, what do I do with it? How do I make choices on the pistons/rods/cam. Also, I haven't had the block tested yet, and I'm not sure if it's stock or over-bored. That's on the to-do list |
If you want to save a buck I have a roller cam that will fit this engine for sale. It's the smallest of the line cam in it's class and it's got great low end torque and it gets better fuel economy than does the stock cam.
If your interested in the cam shoot me a PM. |
If this is a budget build and you're not looking for a bunch of HP, look into a master rebuild kit from Northern Auto. Name brand parts, low prices. You can substitute the stock cam for a RV grind, get the moly rings, too. |
since those heads are the 64cc combustion chamber version of 305 heads i wouldn't go with any more than a 4-5cc flat top piston, cast pistons would be fine. be careful when looking at rebuilder kits as they often sell pistons with a shorter comression height to compensate for any need to deck the block. the factory compression height of a 305 piston is the same as a 350; 1.560", many reuilder pistons are 1.540 (.020" less). make sure you buy pistons that are 1.560", only have the block decked as much is needed in order to get a true flat surface and align everything. if you have access to a die grinder then i think it would be a good idea to buy a head porting book and try to clean up the runners a bit (it can be free hp). the heads will likely need to be plained a little bit as well to get them to a true flat surface, personally i would try to have them take off around .020-.030" to help up the compression ratio a little bit. while this being done i would go ahead and have them rebuild the heads. a simple hyd roller cam around 210° duration at .050 and around .430-.440" lift is what i would be looking to use. a simple performer rpm intake (ditch the factory TBI), then look on ebay for a used/rebuilt holley 600cfm vac secondary carb. also look on ebay for a simple 50-60K volt HEI distributor, should be able to find one for about $60.00. a cheap set of headman headers suited for what ever vehicle the motor is going into. keep you power goal conservitive as with what i have menitioned you might see around 275hp/325tq.
and i still say that you seriously need to read a "how to rebuild a small block chevy" book. SA design makes a very good one, written by David Vizard. |
I had planned on getting the block/heads machined, but that advice is more specific and exactly the kind of thing I need, thank you. As for rebuilding the heads, is this something I might be able to tackle myself? "How to rebuild your small-block chevy" has some stuff in it. Quote:
From hotrod.com: Quote:
Boy, that was alot of writing/questions. Sorry if I am bothersome, I'd just like to learn so that one day I'll know how to make these choices myself Last edited by Perkster029; 06-12-2012 at 11:08 AM. |
Your engine probably came out of a Camaro or Firebird. Only the cars used roller cams in the 80s. It probably won't take much to get 250hp out of it. There was a factory rated 230hp on some 305s. You can put a used cam from a IROC in there, roller cams are reuseable. Look for a used aluminum 80s 305 quadrajet intake and file out the center bolt holes, it will fit those heads perfect.
The first thing you want to get rid of is those exhaust manifolds. The tuned port engines used 2.5 inch dumps on the exhaust manifolds. There are better exhaust manifolds than what was used in the Camaros. The engine will run better if you don't have to run cat converters and restricted exhaust.
Breaking in a cam right is VERY important. More on that here. You can use the Comp Cams CamQuest software to see how different cams affect the powerband. Pay special attention to the changes in RPM where the peaks occur as the cam gets more radical. |
| 283 w/305 heads. 305 head gasket? | malibu65ss | Engine | 2 | 01-16-2003 02:07 PM |
| 305 TBI to a 305 carb engine swap | 91olds305 | Engine | 0 | 10-14-2002 10:10 AM |
