Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compound, buff, polish
Old 05-19-2012, 08:54 AM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by TucsonJay
Yes. 06085 in the purple bottle.
Try it on a small area first, just so you know it will work for you.
Already tried some, its 3m heavy duty rubbing compound came in a half quart bottle for $15. Paint guy said its the same stuff as the big purple bottle. Dont know if thats true, but it works good. I use a wool pad followed by 2 foam pads (1 a cutting, and 1 a polish pad) and a dark color glaze on the the last pad...works pretty well for me and I'm doing a black job.
I was using "system one" before, but it takes way longer. Probably alot safer for a beginner, but they don't even sell it anymore...to me it doesnt really have enough grit for the initial buff. I should try to mix the two, I bet that would actually work pretty good.
Andy
