compresion and head questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2012, 03:35 PM
Does porting and having head work lower or raise compression
Old 02-25-2012, 03:53 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
As far as the heads go, only work done removing material from the combustion chamber itself or shaving the heads flat surface will change the compression ration. Adding (dome) or removing (dish) material to the piston head, dropping or raising the deck height of the piston, head gasket thickness and boring will change static compression ration as well.
Semper Fi
Old 02-25-2012, 03:56 PM
Richiehd's Avatar
JS-70
If you remove material from the chambers you will lower compression. Remove material from the ports, no change. After the chambers are all brought to equal size (cc ing) the heads are milled to bring the compression to the desired compression ratio.
9 to 10.3 compresion tomthecomic Engine 11 11-15-2008 09:55 PM
compresion help johnbelanger Engine 11 02-25-2008 01:23 PM
Compresion ratio 71 c-10 Engine 2 01-17-2008 01:50 PM
More head questions for the head gurus, seen 305 heads with 2.02's 4speed57 Engine 10 07-13-2005 02:14 AM
compresion formula graham83oh Engine 4 01-08-2003 05:44 PM
