Compress Mustang rear disc brake caliper piston - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2010, 04:43 PM
75gmck25's Avatar
The rear disc brakes on my 2005 Mustang GT use a caliper where the piston has to be turned as it is compressed to allow space for the new pads.
I tried doing it by hand with a needle nose pliers, but could not get enough leverage to turn and push in the piston at the same time. The notches in the piston that are used for leverage to turn it are not very big.
I bought a universal tool at the parts store that looks like a little cube with nubs on its. The nubs are supposed to fit the notches in the piston, and you use a 3/8" socket extension to push and turn it. However, I'm not sure the cheap tool will get a good grip on the notches in the piston, and I will need three hands to hold the caliper, turn the piston, and compress the piston all at the same time.
Is this the right method, or have I missed something? A standard C-clamp will not work, because there is no way to turn the piston as it is compressed.
Thanks,
Bruce
Old 06-04-2010, 05:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Thanks,
Bruce
Yep Bruce, That's how you do it place the nubs in the holes and push done by hand while turning the piston in. Don't know if the tool you have can handle it or not but give it your best shot and don't get mad at it just take your time applying pressure and turning it will work. If not i have done it other ways but you try what you have first. Oh they do make a wrench with the nubs also.
Cole
Old 06-04-2010, 08:43 PM
Wiki Edits: 31
b4 I had the tool, I could do it with 1 person holding the caliper and 2 screw drivers.. tool does work and makes it faster, but still requires that second person
Old 06-06-2010, 04:09 PM
75gmck25's Avatar
I bought the little cube tool with the nubs on it, and had to make some modifications. The surface with the right spacing had four nubs and I only needed two, so I ground off one diagonal pair. After that it could get a good grip on the two slots in the piston.
I then proceeded to break the piston loose and turn it with the tool - many times, and it did not seem to go in. I finally went back to the standard C-clamp, and found that as I turned the clamp screw it got a grip on the (now loose) piston face, and rotated the piston and pushed it in at the same time.
I think the best tool would be a C-clamp with the nub tool on the face of it so that it got a very good grip on the piston. This would allow you to turn the piston and put pressure on it at the same time. However, even the Ford tool shown in my shop manual seems to rely on hand pressure to push in the piston.
Bruce
Old 12-20-2010, 11:30 AM
WCL WCL is offline
mustang rear brake lining replacement
I just finished my first brake job on my 2008 Mustang GT. I chose to purchase a special tool to rotate and push the rear caliper pistons on both the left and right rear calipers. The tool kit worked very well and is well worth the $45 from harbor freight. I did not know if the left side caliper (drivers side) would require a left hand thread. It did not. The tool kit includes both left and right hand threads. For $29 a right hand thread is all that is needed. I first purchased the little cube. This proved way too akward and required a third hand. (i tried duct tape to hold the caliper still). the tool kit from harbor freight sure made the brake job a lot easier. snap on wants over $200 for their kit and it doesn't include a left hand thread.
18 Piece Disc Brake Pad and Caliper Service Tool Kit
Item #97143 :$44.99
Caliper Tool Set for Disc Brakes
Item #40732 :$29.99
Old 11-02-2012, 11:06 PM
I'm sure no one will read this but just in case I have a 99 Mustang so I feel your pain, but there is a cheaters way of doing it. Use a C clamp to keep pressure on caliper then use channel pliers every turn or so adjust clamp pressure it takes less time and less frustration this way. It works with no real chance of hurting anything. Just be patient.
Old 11-03-2012, 08:33 AM
caliper
back off the bleader 1st,and i was able to use a screw driver,but like prev. poster dont loose your temper. i am a ford fan but the rear caliper was desighed by a *** ???? cliff
Old 08-11-2013, 10:58 AM
I took me 45 min to finally consult this forum to figure why the rear caliper pistons would not compress. Instead of buying a special tool to use once in a while, I used a quick grip clamp, the type you would find in Home Depot or Lowes. Just install the bottom caliper bolt so it will be supported. Squeeze the clamp hard and turn while holding the caliper. You will have to keep resetting the clam. The clamp is much cheaper and have many more uses than a specialized tool.
Old 01-23-2016, 08:45 AM
I also found that what works well is clamping the cube onto the piston using c clamp, then using a screwdriver or extension in the side holes of the cube to turn, one quarter turn at a time, then tighten the clamp some more, and repeat a few times. It took 5 minutes to do the other side once i figured this out. Thanks
Old 01-23-2016, 03:25 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Yep---my Crown Vic-----same issues
Old 01-24-2016, 05:45 AM
dei8fan's Avatar
Registered Brain Surgeon
Literally a 2 min. job with one of these.
Disc Brake Pad and Caliper Service Tool Kit 18 Pc
Old 01-24-2016, 08:36 AM
Bryan59EC's Avatar
cool----I'll have to look into this for the next time
Old 01-24-2016, 05:42 PM
I use a C clamp Vice-grip have for years and it works fine.
rear disc brake conversion TBear Suspension - Brakes - Steering 6 02-12-2009 06:41 PM
Rear brake caliper stuck? frankenvette Suspension - Brakes - Steering 5 01-14-2008 04:14 AM
91 Mustang Disc Conversion and rear end help sha_ba_do_bang Transmission - Rearend 1 05-29-2006 06:51 AM
Taurus Brake Caliper...Slow Release. awbazar Suspension - Brakes - Steering 5 02-22-2006 04:33 PM
Rear end and disc brakes for a 66 mustang coup treuno Transmission - Rearend 5 04-23-2002 10:54 AM
