compression
My son and i just built a 350 for his 88 Monte SS and was wondering how to determine the compression ratio on the motor (We have been looking at 5psi superchargers). The motor is a 1988 350/060 over, flat top pistons and stock 062 vortec heads.
• The stroke is 3.48". • The gasket bore diameter is around 4.09" and the thickness you should know. • The combustion chamber volume is around 64cc. • The piston dish volume is about -5cc for valve reliefs • I'm guessing you didn't measure the "Piston Deck Clearance" (how far down the hole the piston was at TDC), so if the block is uncut, that's going to be about 0.025". Use the calculator HERE, plug the numbers in as best as you know them and see what you get. |
Dude....i appreciate the reply but i'll be honest back in the days of Math class i had a Big Block chevelle and spent most of my time in the pool hall instead of math class. Maybe my son can figure that one out,he's a collage kid. LOL/Thanks
With FelPro 1094 steel shims, your quench will be correct, but you'll be around 10.5:1.
With the ZZ4 head gaskets you could get around 9.7:1, but that's still too much for 5 psi, especially with such poor quench. |
| compression ratio compared to compression PSI | squids1 | Engine | 14 | 12-28-2010 11:36 PM |
| 383 SBC Max Compression | 1972RedNeck | Engine | 4 | 12-28-2010 06:53 PM |
| Help, ..To much compression | Onsjos | Engine | 4 | 02-11-2009 07:53 PM |
| Enough compression? | 73camaro | Engine | 12 | 10-03-2006 07:56 PM |
| compression | 78 chevy truck | Engine | 20 | 01-20-2004 03:24 PM |
