Compression calculator - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2012, 10:13 PM
This is probably an easy one but Im going to ask it anyhow.....because Im not sure.
If you have a flat top piston with a 5cc double eyebrow valve relief. When you input that info into the calculator would you use 5 or -5??
Old 06-21-2012, 11:48 PM
depends on the calculator.. KB just used 5 as they use a - 5 to represent a dome.. most i would say use a -5 for a relief in the piston.. {non dome} best thing to do is put the figure in and see what you got, if it looks to high with a - infront of number, then just use 5..
Old 06-22-2012, 12:46 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Do that first with a motor's known c.r., otherwise you could be just fooling yourself...
Semper Fi
Dynamic Compression Ratio Calculator 4 U McGurk General Rodding Tech 1 07-04-2011 12:04 AM
Which CR calculator is right? adam83 General Rodding Tech 3 01-06-2010 09:13 PM
Calculator S10 Racer General Rodding Tech 2 06-30-2009 04:36 PM
compression calculator oklowride Engine 6 02-21-2006 12:06 AM
