Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression calculator
Old 02-16-2006, 09:42 AM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
9:1 with iron heads should not be a problem. 10:1 is the "rule of thumb limit" for iron heads and pump gas. If your quench is tight you should have no problems with 9:1 on pump gas w/iron heads.
Royce
